Results 1 to 17 of 17
Thread: Losing antifreeze
    Default Losing antifreeze
    Hi guys i have a 95 integra one night i was racing one of buddies and afterwards i noticed a smelled antifreeze. Did think anything about but the next day i looked in the radiator and no antifreeze, so i replaced a hose that i thought it might be and toped off the radiator. But for some reason it keeps losing antifreeze and i keep smelling it but it aint leaking out. I NEED HELP PLEASE!!!
    barrow county
    at least you had the balls to till i.a you were street racing lmao
    first of all, antifreeze isnt magic so it dosnt disappear
    if its not leaking its burning off
    check what color smoke is coming out of your exhaust
    white would be antifreeze
    ^^this guy loves you jdm-civic's Avatar
    the sky
    if your smelling it then it has to be escaping. did you check all the other hoses and look for leaks?
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    Yea I looked at all the other hoses none of them r leaking and it doesn't smoke
    But wat I can't understand is that it runs fine it doesn't run hot or anything
    Stang Mod slostang's Avatar
    Southside
    pressure test the cooling system, and do a compression check on the engine. that should tell you where its leaking.
    barrow county
    yea like what he said, compression test cooling system and engine
    slostang when you gona drop that thing lol
    Southside
    never. it rides like a Cadillac.
    if u still got issues hit me up.
    It could be a head gasket if the coolant is being pushed out the radiator cap.
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    also make sure your passenger floorboard is not soaked. if so, mind as well be taking out the dash.
    98 Acura Integra LS-DD
    ??????????????????-project
    Texas
    You might be able to take your spark plugs out stick a flashlight down there and see if the top of your pistons are clean.(headgasket) Its a short -cut way, but a compression test would be the most accurate way.
    Went and looked at it when I Rev it up water or antifreeze is coming out the exhaust.
    Southside
    Sounds like the head will be coming off soon...
    It's all about JDM.
    CA to GA
    Okay lets break it down.
    Coolant can only be lost if it is leaking or burning. Now First thing first, if you dont have a radiator pressure tester, i advise you go rent one at Oreilly's. If not, you gonna have to use a bright flashlight and inspect your radiator (see if its not cracked anywhere). Next, inspect your radiator hoses for cracks, leaking, or looseness. Inspect the area around the motor and where the head mates to the block, and under the motor (Like really inspect it, don't half-ass it ). If no signs of leaking at this point, then next inspect your cylinders, by pulling each spark plug out. Use a small LED flashlight, shine it down each cylinder and sight any moisture or puddle of coolant on top of the piston...Sniff if you have to, if you see signs of moisture/fluids (and if it smells like coolant, your headgasket is likely blown). Your exhaust should be puffing out white smoke, and your car should sound like it's running on only a few sparkplugs (sounds like it wants to die)
    Well is your car overheating?
    Could just be your thermostat failure to cause you to have low coolant fluid.
    But all in all, inspect all components of the cooling system, before actually spending money. It could just be a minor fix.
    TALKING ROCK, GA
    blown head gasket...
    Certified Gearhead Thegrizz's Avatar
    Feb 2010
    Georgia?.
    yea im gonna say blown head gasket.that will cause your car to do all kinds of weird shit
