Results 1 to 2 of 2
Thread: b20 spark problems
    1.5T AnTi-PooN's Avatar
    L'villE
    Default b20 spark problems
    i have a 99 crv with a b20 i just replaced the timing belt and i have the white park on the crank lined up with the pointer
    first ? i was told to line up the white notch not the 3 grouped notches is that right?
    2nd ? i am not getting any spark i have tested the dizzy with with a volt meter and it is good any suggestions please help
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    yes the white notch is the one on the crank pulley you line up. the other three are measurements for BTDC. check the ignition coil in the dizzy. if still no spark check your wires
    98 Acura Integra LS-DD
    ??????????????????-project
