Results 1 to 5 of 5
Thread: Two 0 mile 2.2l ecotecs and a super low mileage MA5 5-speed
    IA Member zachscar's Avatar
    Gainesville, GA
    Default Two 0 mile 2.2l ecotecs and a super low mileage MA5 5-speed
    I have two 2.2 L ecotecs, I believe made for the Saturn Vue, they were used at a Tech school so they have been taken apart and put back together a number of times. These motors, as far as I know, have never been fired. If they have it was only on a bench dyno to ensure they had assembled them correctly. I believe the Vins are 10rwbt106260031 and 10rwbt107270251, that's what I found as the designation codes on the front of both engines. If this is not correct someone please tell me where exactly I can find the vins and I'll get them up Asap. I was planning on putting these in some Locost projects I'm working on, but ran short on funds big time and have other plans now, so I need to get rid of them. One is torn down to a long-block but can be put back together if I get an interested buyer, or can be sold with all the parts. The other is still fully put together. They've even got majority of the accessories and wiring harnesses, including alternator, and one has an A/C compressor, I believe I sold the other A/C compressor.
    There is only 1 transmission it came out of a wrecked Solstice or sky that was wrecked right off the lot, it's the same transmission that's in the Colorado trucks also. It's an MA5 if I'm not mistaken and has ~25 miles on it. There's no clutch, flywheel or starter for either motor. There are 2 flex plates however.
    if for some crazy reason better or more pictures are needed let me know of what and I'll get them up right away. If you have any questions please read everything first and then ask and I will answer to the best of my knowledge as quickly as possible. I can be reached directly via e-mail Zjunqueraatgmail.com or phone 678-936-722eight quickest and I'll check this as regularly as possible.
    750 OBO for each motor
    750 OBO for the transmission
    Gainesville, GA
    bump!
    Scottish Scotsman's Avatar
    on the road to recovery
    damn i would love to have one of these as a back up for my VUE , good luck with your sale
    Gainesville, GA
    They're 2.2L ecotecs, they'd fit fine if you swapped over externals on most ecotec vehicles I believe. Would work fine for anyone wanting a spare engine for a mean build. I don't know if I mentioned it but they come with harnesses.
    Gainesville, GA
