Results 1 to 4 of 4
Thread: How do i get my d15b7 in time
    Certified Gearhead kbiais's Avatar
    conyers
    Default How do i get my d15b7 in time
    just dropped in engine everything hooked up but dizzy from old engine need to know how to put it in time now heres the delima no timing tools ne help is appreciated want to get it running by tonight thanks
    sweetspeed Mr. Fix-it.'s Avatar
    Musella, Ga
    the cam gear should say up. move it till up is up. haha. and as for the crank, it will have a knotch on it. the oil pump has a mark on it as well, just line those up.
    conyers
    preciate it mane i took top timing cover off made sure the first cylinder was at top dead center line the two notchs in my cam gear with the head and wala she is on thanks for ur help i knew just about how to but wasnt sure started tinkering and got it
    Titties!!!
    it depends on what type of ecu you ahve, motor, snd the dizzy you are using. if sll things are there then you should be good. more info on your set-up would help us a lot better. if everything is right then you would need to jump the service connector while adjusting the dizzy with a timing light to get it right. all i can say for now
