Results 1 to 10 of 10
Thread: Car will not start...PLEASE IA HELP ME!!!!
    Default Car will not start...PLEASE IA HELP ME!!!!
    Okay...here are the facts...i just swapped in an obd2 jdm d15b into a 96 honda civic ex...i got it up and running and it was driving fine for about a week...but now it just wont start...i checked everything...spark...fuel...and timing...i just dont know whats wrong with it...i even checked the main relay...and its fine...the motor has brand new spark plugs and wire...IA please help...
    im down right fierce hadouken's Avatar
    check the fuses.. its what was wrong with mine.. im local if u need help i could come by and help 770-601-8503
    yea forgot to mention i checked all the fuses also...
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    check compression. have you sprayed carb cleaner in intake while trying to start it up? if it runs you have a fuel problem, possible injectors
    98 Acura Integra LS-DD
    ??????????????????-project
    iono car is wierd...the car will start up for about .5 secs...and shut off right away...thats on the first turn to try and start it up...other then that car will not come on if i keep trying...please any info will help...but ill check compression...
    douglasville
    Quote Originally Posted by PiGeOn View Post
    tps
    okay i check fuel...spark...and timing...everything is good...but if i spray starter fluid...then it will crank and stay on if i keep the throttle open and keep spraying...please lmk...
    Still need help...i have done everything...i checked compression and everything is fine...spark and fuel is there...changed out main relay...and still car wont start...but if i spray starter fluid into the throttle body...the car will start and run as long as i keep spraying starter fluid...is it a sensor problem...please HELP...
    Titties!!!
    if it runs on fluid i would ask how long the mktkr sat before you used it? could be carbon on a sensor or the injectors are old and don't want to work right or are clogged. check them and clean them.
    Certified Gearhead Thegrizz's Avatar
    Feb 2010
    Georgia?.
    So it is getting spark?
