- Everything D-Series
is dead
- Rep Power
- 0
Everything D-Series
So i swapped out my d16y8 for a B16
I have a mass load of parts lying around that need to be gone. Girlfriend won't take much more of the boxes and bins of parts around the crib....
So the list and prices and they are all O.B.O.
D16y8 Block $200, it was knocking when i pulled it, the cylinder walls, cylinder are fine, so needs new bearings most likely
D16Y8 Head only $150 (pending sale)
Whole motor for $325
D16Y8 Intake manifold bare $40
Throttle Body Cable $20
Fuel Rail w/ injectors $40 fuel line $25
Engine Harness Auto (obd2) $50 (it's missing one plug, but its an easy replacement)
ECU P2P (obd2), for auto $50
Motor/Tranny Mounts $30 per mount
Gas and break pedal assembly $75
Cruise control unit $60
Auto Shifter $30
Pullies - $25 cut a deal for all of them
Front and rear control arms (camber) $75 for all
Auto Axels $50 each
B-series Header, stock $80
A/C compressor $50
Power Steering with reservoir $60
Auto Pedal Assembly $50
Stock Honda CD Player $40 worked when pulled, may have display issues
Areo Turbine Resonator $50
Honda Timing belt less than 10k on it $30
Alternator $60
Oil Pump $60
Cam Gear $30
Misc stuff you need...starting at $10 just ask what you're looking for i have pics of everything!
I literally have almost everything for a d-series just pm me for what you are looking for and i'll get back to you asap, Will send pics via text, just send me a list of what you want. I'll have pics up here soon....at work right now
Thanks
Reason: add ons
- You may not post replies
- You may not edit your posts
Forum Rules
