- gsr swapd eg help
gsr swapd eg help
yo ia i got a92 hatch with a gsr swap. its got a lil over 1100 miles on it and itll run fine til i stop and cut it off for a short amount of time or as long as its still warm...when i take off in first,between 1000 1500 rpm it will violently jerk, and sometimes it straight up dies on me... italso jerks in the other gears....as long asits at a lower rpm itll do it...dunno whether its a bad fuel filter or what...any advice will help...codes showing are 23-knock sensor (engine currently isnt rockin a knock sensor)...and 41 primary o2 sensor heater....ive got a p72 on it currently but i also have a p30...both ecu's throw same codes and run it the same shitty way.....im not on here very often so if youd like to text me advice,,,423 994 2534 thanks duuuudes
- gsr swapd eg help
- You may not post replies
- You may not edit your posts
Forum Rules
