Thread: oil restrictor on a super 20g
    Soul Crusher RUFFIAN's Avatar
    in your nightmares
    Default oil restrictor on a super 20g
    Ok guys Im hoping that someone can let me know if I need to put an oil restrictor on my super 20.
    N/A>>><<<BOOST
    Depends on the vehicle you are using it on, but I usually use a restrictor on most turbos i install.
    Flowery Branch, GA
    No. Unless it is a ball bearing. What size feed line are you running to it?
    ---Mike
    Twan Jdm94Coupe's Avatar
    Fairburn
    How do you know what turbos need an oil restrictor and which don't?
    in your nightmares
    Quote Originally Posted by crashtke View Post
    im not sure of the line size. 3AN (possibly) no it not ball bearing. its oil and water cooled.
    N/A>>><<<BOOST
    Northwest Georgia
    ball bearing typicall need a restrictor but is not required. Standard turbos need just a -3 feed line until you go to a large frame(gt42, s372) turbo which generally needs a -4.
    Flowery Branch, GA
    You should be fine with -3 line.
    ---Mike
