Results 1 to 14 of 14
Thread: Lude cranking on its own
    GWINNETT IS GREAT!
    Default Lude cranking on its own
    I have a 92 prelude si and this morning as i go to start the car, it didnt crank the 1st time..nothing out of the ordinary, but as i was about to give it another turn, it cranked on its own and was running really crappy and making screeching noises..so i try to turn it off and it wouldnt cut out!! .i pulled the keys out and IT KEPT TRYING TO TURN OVER!!
    i had to unplug the battery terminal...
    and everytime i try to connect it, it trys to start on its own...
    where should i start?
    Starter and cabling running to it.
    Southside Ridin HATCH
    DAMN!
    this is a first i have seen on IA..
    Sounds to me, your starting is getting power/ground when it shouldnt be..
    Новак 5speed's Avatar
    Conyers, GA
    DAMN!
    I agree. My dad had a car that did this and he rewired the whole thing. If I can, I will get details on the exact problem.
    Amen.
    barrow county
    get this fix soon son
    a guy from my school civic did this and it end up with a fire.
    a hot wire was cut open and touching his starter. since the key wasnt on, engine wasnt getting fuel so it wont fire up, but it'll just keep turnning
    EASIEST WAY TO FIND THIS OUT IS TO WAIT TILL DARK AND HOOK THE BATTERY UP, YOU'LL SEE WHERE ITS SPARKING
    GWINNETT IS GREAT!
    i replaced the starter...it sounds really weird when cranking up...but have only turned it on twice...hope it continues to work
    barrow county
    you might have striped the teeth of the flywheel
    Do you have a security system?? When I bought my '97 lude it had a shitty alarm system with remote start. It turns out the remote start was acting up and tried to start it on its own.
    i agree with wires crossed. if u dont get it fixed hit me up.
    GWINNETT IS GREAT!
    update: i kno nobody gives a shit but
    that weird cranking sound went away as mysteriously as it came....i guess the fresh part being put in had something to do wit it...but it cranks up the way it normally used to!!
    thanks for your help everyone!
    Certified Gearhead Thegrizz's Avatar
    Feb 2010
    Georgia?.
    ur starter /ignition switch if fucked. prolly your starter grinding was the screeching noise.u have to disconect your battery to stop it cuz ur switch is stuck on start.
    Feb 2010
    Georgia?.
    lol.sry.just noticed you fixed it. glad its fixed
    IA Member 5thgenlevi's Avatar
    Apr 2010
    Augusta, GA
    call an exorcist, your car is possessed man
    X2 on Remote Start. I would push the remote start while walking to the car, it would make a click sound which I think was the fuel pump getting power, but didnt crank. I'd sit down, close the door, and all the sudden it'd crank itself.
    Preludes are a whole different Ballgame.
