Results 1 to 22 of 22
Thread: F20A Anybody...?
    KNXWLEDGE EssexCounty's Avatar
    South Side
    Default F20A Anybody...?
    I have an 93 Accord w/ an F20A SOHC. Has anybody on here messed with these motors n/a..? If so any good setups that makes decent numbers..? Goals are 195hp+. I thinks its reasonable.
    BK all day APEX i GSR's Avatar
    Is it a green SE Accord?
    i had one where i put the motor in & i always wondered what happened to it
    South Side
    NO! Its a maroon with clear comin off
    Out the game again!!
    southside of the border
    i tried searching some builds couldnt find any
    Soon!!
    Ol School Pimpin' brownhornet's Avatar
    chillin' in the burbs
    Check here: www.cb7tuner.com
    The forum is specifically for 90-93 accords. I'm sure you can find some info there.
    Will work for food, car parts, or three stripe apparel. And not necessarily in that oder.
    higher compression pistons 11.5 - 12.5 and bisimoto level 2 cams should get you there. or nitrous oxide.
    About to approach beast mode
    Basic high quality bolt ons, pistons, cam and a good tune. Should be close.
    I say go for boost. Boosted F's are fun. I made over 300 on my stock F22A1. I'm swapping in a dohc f20a now and going for 300 with less than 10psi. Good luck with the build.
    South Side
    Sounds good.. I've read about h23 mainifold/throttle body adds a little power
    NA/Boost I got both. Supraboy87T's Avatar
    Jul 2009
    Not sure about the F series but I love a nice built Na SOHC. Wait that's only cause I'm building one lol. Good luck and hope to have the pleasure of running it once it's done.
    Quote Originally Posted by Supraboy87T View Post
    just think of the F series as a bigger displacement D series. just a cam and head work makes a big difference.
    check out this F series build: http://www.cb7tuner.com/vbb/showthread.php?t=139885
    Feb 2010
    Zebulon
    the f series is a cast iron block, great for turbo. at that, alreadey being a low compression motor, just like the b18b1, loves boost. get a cam, better intake, throttle body and a tune. dont know if youll pick up 55 horses, bit reasonably 30.
    South Side
    Bump... H22 IM/TB picked up... Has anybody done this mod...?
    Quote Originally Posted by Looney Tune View Post
    you can only use the upper section of the h22 im and tb. you will need the h23 or f22a6 lower im.
    i currently have the h22 upper and a6 lower.
    South Side
    I think I understand what your trying to say.. Is there a thread on this somewhere...?
    there is one on cb7tuner, you will have to check the d.i.y. threads and search for it. but its an easy swap.
    we are having a cb7 meet the second weekend in september
    I've got an F22B2 intake manifold laying around if you need it. Haven't checked to see if its the same as f22a6, but It if it works you can have it for a couple bucks.
    its a different bolt pattern from the f22a IM's.
    South Side
    Quote Originally Posted by K24cb7coupe View Post
    My friend was swapping struts and I was lowering my car.. Kinda took longer than expected...
