Results 1 to 3 of 3
Thread: charge a cap?
    vQ350zHee esco97civicR's Avatar
    gwinett
    Default charge a cap?
    are you supposed to charge up the cap befor hookin it up to the amp?
    Yes, that is correct.
    Cumming, GA
    Most capacitors come with a resistor that you temporarily put inline between your power wire and the positive terminal of the cap. This will allow it to charge slowly.
    You "can" do it without a resistor....when you touch the positive wire to the capacitor terminal you will get a small "spark".
    Using the resistor is "right", not using it "works" just fine though.
