Thread: Water Pump on 95 Legend went out.
    Default Water Pump on 95 Legend went out.
    So the first major repair on the Legend since owning 2 years ago. I replaced the belt and water pump on my H22 but don't want to try on the Legend. What can I expect to spend?
    del sol? 94_teg_ls's Avatar
    pm barefoot
    /sig
    Thanks. Good price also. Gonna check under car, was told to check the heater core drain also since I smell a faint bit of coolant every blue moon and when the heater core starts to leak on a Legend it leaks in the same spot as the AC drain plug, wich is what my puddles look like on the ground, coolant and water in same puddle.
    Definitely not Heater Core. Looked under car and coolant was dripping near AC compressor on backside. Coolant looked like it was coming from AC compressor so I believe part of the water pump is over in that area also.
    barrow county
    Thanks. I just found that.
    Quote Originally Posted by 94_teg_ls View Post
    pm barefoot
    repped
