Results 1 to 4 of 4
Thread: oil level
    Mar 2010
    Default oil level
    just wondering what is the corrected oil level for my turbod d16 ? i always keep it a little above the second dot. does this sound right ?
    its got a blow dryer jdmDC20's Avatar
    Apr 2010
    L'ville
    I've always thought in turbo cars you just need enough to add for the turbo lines/turbo/oil drain. which isn't a whole quart or even close to half a quart. In my b18 turbo i keep it right below the second dot. and my reasoning for that is, if i ran it with the line in the middle of the two dots when i was stock, then keeping it right below the second dot now would mean im adding a little under half a quart. which is enough in my opinion.
    having to much oil pressure can also be bad for the car, and turbo.. most turbo feed lines come with a resistor for that exact reason. I would look into getting a little more insight on this other than just me, i'm not a mechanic, this is just what i do and how i justify it.
    Mar 2010
    ok. well thanks for the info. ive been looking into it and havent really found anything thats why i was asking this question
    West palm beach
    Quote Originally Posted by ej1boy93 View Post
    just keep it on the full mark, if you wanna add a tad more for the oil lines thats fine, but it won't matter, unless you're running a water hose size line...
    NO ADVERTISING
    -IA MANAGEMENT
