Results 1 to 2 of 2
Thread: F/S: Collingmist 1.5 Gal met Kit with Smart Injection Controller
    Weekly Gwinnett/Junciton Meet
    Default F/S: Collingmist 1.5 Gal met Kit with Smart Injection Controller
    I never ended up using it and it just sitting in my garage. Letting it go cheap, first come first serve.
    Part: Cooling Mist 1.5 Gallon Trunk Mount meth kit (comes with everything pump, nozzels, fittings, straps, lines, etc, not a part missing).
    Extras: Smart injection Controller: Can Alone sells for $220:
    http://www.coolingmist.com/detailmain.aspx?pid=1099
    We call it smart injection for a reason. Its up to you, the customer to determine what you want to to. Smart injection can take you there..that is if you can imagine it.
    Infact...you can run your nitrous from this controller, but not only run your nitrous, integrate it with your water injection. That way you can make sure that you only run the nitrous if the water injection is running..
    How about a RPM switch or RPM window switch? Or a switch for any input (RPM, TEMP, EGT, etc). The sky is the limit If you order our Coolingmist flow Sensor you can use the smart controller as a 5 channel failsafe. You can turn on or off upto 5 devices based on flow range or any hardware failure. this is also a stand alone fixed rate methanol injection controller.
    Condtion: Good working, was used for 5000 miles.
    Price: $375...no lowball or u can go get it new.
