Results 1 to 15 of 15
Thread: OBD1 Chipped Vtec ECU WINFAB
    Default OBD1 Chipped Vtec ECU WINFAB
    Came with my OBD1 B18c1 GSR swap i picked up. Previous owner said it ran fine for his swap. It has a winfab VTEC chip. Looks to be in good shape and ready to drop in. Not sure what other motors it can run but i'm sure one of the vendors in the sponsor section can re-program to your liking. $50
    Not looking for trades.
    bumparoo
    eg6
    Apr 2009
    any trades.
    Well since you asked.
    I only need parts for my rebuild below, lol. Need to be new OEM in the package too. Only items i would consider used are those timing belt covers (prev owner mangled the one i bought ). Otherwise need cash money to keep progressing on the build....
    Part part number qty
    Upper timing cover 11820-P72-000 1
    2 bolts upper timing cover 90010-PR3-000 2
    timing cover bolt lower 90007-679-000 5
    lower timing cover 11810-PR3-010 1
    gasket lower timing cover 11831-PR3-000 1
    timing tensioner plug 11812-PJ7-310 1
    lost motion c-clip( lost motion assy) 14820-P30-010 1
    vtec gasket pressure switch broken (switch assy valve timing oil pressure) 37250-PR3-003 1
    vtec gasket pressure switch broken (O-ring) 91319-PR3-003 1
    GASKET, SOLENOID BASE 36172-P08-015 1
    INTAKE VALVE SEAL 12210-PZ1-004 2
    EXHAUST VALVE SEAL 12211-PZ1-004 2
    Main bearing upper (1) green 13324-PR3-004 1
    Main bearing upper (2) green 13324-PR3-004 1
    Main bearing upper (3) YELLOW 13325-PR3-004 1
    Main bearing upper (4) brown 13323-PR3-004 1
    Main bearing upper (5) green 13324-PR3-004 1
    Main bearing lower (1) green 13344-PR3-004 1
    Main bearing lower (2) green 13344-PR3-004 1
    Main bearing lower (3) yellow 13345-PR3-004 1
    Main bearing lower (4) brown 13343-PR3-004 1
    Main bearing lower (5) green 13344-PR3-004 1
    Connecting Rod (1) brown 13213-P72-003 2
    Connecting Rod (2) green 13214-P72-003 2
    Connecting Rod (3) green 13214-P72-003 2
    Connecting Rod (4) green 13214-P72-003 2
    Piston rings GSR STD 13011-PR3-004 4
    O-RING VTEC (O-RING 6.8X1.9) 91306-PJ4-000 2
    Cam seal end plug (cyl head seal) 12513-P30-000 1
    dist O-ring / housing (O-RING 26.4X3.1) 30110-PA1-732 1
    Cam seals 91213-PR3-004 2
    Intake Gasket 17105-P72-004 1
    THRUST WASHER 13014-PR3-S20 1
    Oil pump O-ring 91302-PF0-003 1
    Coolant back pipe O-Ring 91314-PH7-003 2
    cooler Oil O-ring / hoses 91316-PT6-003 1
    Oil cooler hose In. 19422-PR3-000 1
    Oil cooler Hose Ex 19423-P72-000 1
    Oil pan gasket 11251-P30-004 1
    front crank seal 91212-PR3-003 1
    Rear main 91214-PH1-013 1
    Thermostat 19301-P08-316 1
    Waterpump 19200-P72-003 1
    Breather O-ring hose (grommet breather chamber) 11853-PR3-000 1
    PCV VALVE GROMMET 11855-P72-000 1
    BULK HOSE, VACUUM (7.3 X 3000) 7.3 X 120 95005-75003-10M 1
    PCV TUBE C 11857-PR3-000 1
    Filter assy, Spool valve 15825-P08-005 1
    Oil pressure switch Unknown 1
    Valve cover gasket set (Head cover gasket set) 12030-PR3-000 1
    Spark plugs PFR6G-13 NGK 98079-56A7H 4
    Timing belt 14400-P72-014 1
    timing tensioner 14510-P30-003 1
    Oil strainer gasket 15221-PW0-S01 1
    CAM HOLDER O-RING UNKNOWN 1
    Cap nut (chrome 6mm) 90213-PH3-000 8
    Head cover nut 90212-PR3-000 4
    HEAD COVER WASHER 90442-P30-000 8
    Head cover Bolt A. 90014-PR3-000 1
    lowered price. Can't really go any lower since i can get more for it elsewhere. Here is your chance to have a chipped ecu and re- program for different tunes etc....
    bumperoo
    YR88 Win! Romeo's Avatar
    Middle Ga.
    $50? Oh wow i want this.......
    Quote Originally Posted by Romeo View Post
    Come pick it up, lol. That is dirt cheap for a chipped ecu. I will take this off the market soon since the interest for this item is next to nil.....
    I NEED MONIES
    Jul 2009
    Albany
    Is the J1 circuit cut or jumpered?
    Quote Originally Posted by KinZee View Post
    I don't know where it is. Post a pic of where it is. I looked and found squat. What does it do?
    IA & its dead member MeanMugen's Avatar
    Boston
    you have a pm
    Quote Originally Posted by MeanMugen View Post
    you have a pm
    PM'd back LMK.....
    SOLD
    Nov 2009
    Atlanta Ga
    What year GSR is the Ecu used for and where there any check engine lights with this ecu
    Quote Originally Posted by DarrylR View Post
    SUMBISCH it sold, lol. You must not be good at interpreting descriptions. Not event the slightest, lol. OBD1 and previous owner ran it, i did not. Just wow.....
