Results 1 to 2 of 2
Thread: FS: 2AZ-FE Motor Parts
    L'ville
    Default FS: 2AZ-FE Motor Parts
    Well, as an unfortunate event has come up I need to sell my motor project. This is out of a 2009 Camry that had 54k miles. The motor was run low on coolant and the head gasket failed in result warping the head (0.37mm warpage to a Toyota minimum of 0.08mm). The block has no warpage and looked great throughout. Motor has been completely dissasembled and is boxed up for now.
    On to the prices (do not include shipping & PP)
    -Short block (complete) - $400
    I will not part out the block unless I find a buyer for all parts
    -Pistons and rods - $150
    -Crank w/ balance shafts - $150
    -Bare block w/ pans - $100
    -2AR-FE 90mm pistons w/ pins- $200
    Head parts:
    -Complete valvetrain and cams w/ Gears - $175
    -Polished Valve Cover (not perfect and without flaws, but still a nice piece) - $75
    If a local wants this junk head to play with (it already has some porting marks from a bored day) - $30
    And another local only item, an aftermarket exhaust manifold w/ cat that has a great exhaust flange to make a custom header or turbo manifold from - $20
    All parts are preferred to locals, but if I have to ship I suppose I will. It will not be cheap. I am not going to put it back together so I can ship it in one big box, and my crate is being occupied by my 2AR-FE. All items are located around the Buford/L'ville, GA area.
    L'ville
    block pending bump
