Results 1 to 21 of 21
Thread: e85 builds
    Certified Gearhead zenkiAM's Avatar
    Gainesville
    Default e85 builds
    wat u guys think about it? e85 is a 100+ octane if im not mistaken.. would a high compression e85 daily driver be stupid or a beast yet exspensive? just looking for some insight
    s14? sold..
    01 bb6 62xxx orig. miles91xxxmiles 103xxxmiles
    Certified Nissan/Infiniti Tech 1/23/09
    Gwinnett Place Nissan Tech 2/18/09
    no more nissan
    Northwest Georgia
    i use it in my race car and love it, 3 hrs of dyno tuning, 2 test n tunes, 2 race events and my pistons still shine lol. Its good stuff. Availability determines a DD type setup, but it won't be viable for a DD that you take out of town since E85 is not everywhere right now.
    MEGATRON 112480's Avatar
    Mobile,AL
    I plan on using it for my DD civic. There's plenty of them around town BUT like spoolin said, depending on where u go outside of GA, u might want to check on availability in that state b4 u make the trip. Now if u have a trailer thats a different story...................
    EBTEC
    EMMINO BUILT
    Allmotor K EK Hatch Coming Soon.....
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    I use it, and love it. Cheap race gas.
    Who knows?
    Northwest Georgia
    i suggest tuning it on both fuels, do a dual map setup with a switch. if you are on E, and theres not one around, just flip it and fill it.
    time for the build! jerseyef9's Avatar
    SOUTHSIDE
    you are only allowed to hit switch on s300 right? spoolin?
    R.I.P Booga
    M.A.P
    F.D.L.R
    Jun 2009
    Southside, ATL
    Quote Originally Posted by jerseyef9 View Post
    there is also AEM and im sure there are others. Also isn't that mainly for turbo guys, i dont think all motor can switch like that but im not sure
    what do you need to switch a car over to e85? i'm very interested. is it expensive?
    Northwest Georgia
    you can use a dual map switch on NA or FI, theres no difference there. Depends on if your EMS will support it.
    To upgrade to E85 you have to upgrade your fuel flow capacity by atleast 30%
    Example, my car dynod 840 whp last year on gas and 1600's with aeromotive a1000
    this year i dynod 850 on E85 with 2200cc injectors, and an Aeromotive Pro this year....im putting a voltage booster inline to let the pump support about 950-1000 when i want it to on e85.
    damn. Your car is a beast.
    Northwest Georgia
    thanks im finally starting to get it dialed in, some better suspension and continue doing what im doing and we'll get into the mid 9's.
    Jun 2009
    Southside, ATL
    are 440's good to run e85 with i already have a 255 pump fuel pressure reg
    North Augusta, SC
    Quote Originally Posted by Robinson View Post
    With the power you are making I would think it would be safer to up your injectors some more. (especially if you are planning on getting a better tune for better numbers.)
    Back to being stock and slow
    Northwest Georgia
    your power capabilities drop when you switch from gas to e85 without upping your inj sizing.
    Jun 2009
    Southside, ATL
    Quote Originally Posted by SPOOLIN View Post
    oh really maybe i'll move up to 550's
    Mobile,AL
    Are u N/A or FI? f course N/A wont need as big of injectors as FI but but setups will need upgrade fuel pump(255lph)
    EBTEC
    EMMINO BUILT
    Northwest Georgia
    if you make 500 on gas and you are running 85% duty cycle or more at 500hp on 880's....then if you switch to e85, you must upgrade your fuel capacity by 30% to make the same power....your pump might not be maxed, but the injectors could be...so you'd need 1200's to sustain e85 and probably add an inline bosch pump.
    this is just an example.
    02 WRX patrick4588's Avatar
    warner robins
    spoolin, i would think you would trap higher than you do. are those old numbers?
    GCO Member
    NRA Member
    Mobile,AL
    Exactly and the $2-400 cost for bigger injectors is WAYYYYY better than $7+/gal race gas when e85 is $2.50/gas give or take a little more.
    EBTEC
    EMMINO BUILT
    Northwest Georgia
    Quote Originally Posted by patrick4588 View Post
    We're still dialing the first 330 in. so it hasn't made a complete full power pass, ive been hooking very well under powering the chassis turning it up gradually. When you hook to much, your trap is lower. There is such thing as hooking to much.
    Suffolk, VA
    It's a good problem to have though.
    Who knows?
