Thread: full 00' b16a2 swap must sell QUICK!!. . .
    Certified Gearhead jdmda9's Avatar
    Default full 00' b16a2 swap must sell QUICK!!. . .
    k so i have a good running full b16a2 swap w/ a y80 ls tranny from a 00 fbp civic si. the swap has 139,XXX miles and counting since its still currently in the si.
    overall, the swap runs fine. no oil leaks, cracks, wires cut, damage basically. swap has potential!
    the swap will include the following:
    -b16a2 long block
    tranny code: pic! 1072220 good condition overall!
    block code: pic! 5318963
    -y80 ls tranny. not sure what year the tranny is??
    -dc2 teg axle's
    -dc2 teg linkage
    -obd-1 dc2 engine harness (uncut)
    -obd-1 dc2 dizzy
    -half shaft
    -t bracket
    -a/c bracket
    -a/c compressor
    -exhaust manifold (stock header)
    -dc2 teg mounts
    -p2t em1 ecu
    the whole swap. .! swap will be basically set up for a 0bd-1 ej1 coupe swap.
    the swap is currently sitting in the original fbp si if you'd like to test drive it before the purchase. car runs fine and has potential. lightly smokes when you get on it after you've babied the car for a week or so. but the light smoke that does appear seemes to be because of the car running lean and is apparent since the civic is barely ragged out. but once purchased, it will come with all obd-1 parts as stated above. thats because the si is going to have another built b-series swap put in it soon, which is currently 0bd-1. the needed parts will be swapped over from one swap to another so that the si will run the way it's supposed to using the obd-2 parts instead of the obd-1 pieces to avoid cel's, etc. however hurry because the swap will be out in about 2 weeks if you wish to test drive it before then. afterwards, the swap will then have all the obd-1 parts on it.
    like i said, its priced at 2,000 obo and needs to go quick! make me an offer! im located in fulton ga.
    if theres anything else, lmk at 404-704-4614 txt/call names bryan. thanks.
    p.s. if im missing anything mods, lmk asap i would greatly appreciate it! later
    shhh...
    vtec game scArY. . !
    ls2
    Anniston,Al.
    glws with the sale. One bit of info though. Everything i have seen the y80 is a gsr trans..
    2006 gto 6 spd intake/wr 12.8@108
    2003 Chevrolet Tahoe Lt stock dd for the wifey
    1994 Honda civic EX Sdn stock dd for me
    barrow county
    lol at the filter
    but good price
    Privateer Racing!!
    Duluth,Ga
    b16a2 have VIN number post it up!!!
    Quote Originally Posted by B18c1Turboed View Post
    will post up asap!!!
    shhh...
    LAWRENCEVILLE
    Pm me when you have the vin
    Hella stock member!
