Results 1 to 11 of 11
Thread: Need diagnostic help
    RedHenRacing #02 Stuntman G's Avatar
    Jul 2009
    Default Need diagnostic help
    1990 Civic LX Sedan. Bone Stock dual-point D15B2.
    So basically one day I came home from work, parked my car. Went back two hours later and it would turn over but not start. Has not started since. It has no spark at all. Power is getting to the dizzy (via the black/yellow wire) and we tried a full dizzy assembly (wires, cap, rotor, everything) off of a perfectly running car and it still does not get spark. According to a multimeter, the head is a perfectly fine ground. We also swapped the ecu off of the running car and still nothing. Any ideas?
    INSIGHTFUL DIALOGUE ANALYSIS: Actually, Hector, that is not what we call valet parking. Valet parking is where someone parks your car for you. You just pulled your car up to the front of the store and got out. We just call that parking.
    I MAKE THESE
    ^^this guy loves you jdm-civic's Avatar
    the sky
    check main relay
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    Jul 2009
    We also used a brand new main relay, forgot to mention that.
    I MAKE THESE
    give me a call set up and apt $85 diags.
    Give us a call, we'll see if we can get you going.
    Titties!!!
    those little d15b2's it's prob something simple as hell with that car.
    sweetspeed Mr. Fix-it.'s Avatar
    Musella, Ga
    nvm....thought of something but then i read your post again..... i feel dumb.
    Titties!!!
    i have plenty of ef sensors and parts so if you have any ideas let me know i'm looking though my ef book now.
    Titties!!!
    there are 10 solutions to the problem. battery loose or corroded, leaking fuel injectors, faulty carb or fuel pump or FPR, fuel not reaching the rail, ignition components damp or damaged, broken loose or disconnected wiring in the starting circuit, broken loose or disconnected wires at the coil or faulty coil.
    is your dizzy o-ring shot or leaking?
    Jul 2009
    All the dizzy stuff has been thoroughly gone through. I had 9 members, including 4 mods, from the ef forums over last weekend to help, and literally every single one was standing there scratching their head. We were all totally flabbergasted. Finally found yesterday that there is a relay just above the hood pop lever under the dash, that basically shakes hands with the main relay and says 'ok, lets get this bitch goin.' I put a new one in just to try it and it fired right up, ONCE. I guess theres a short somewhere that is causing it to blow. With these relays at $30 a pop, I better get it tracked down quick.
    I MAKE THESE
    Titties!!!
    Quote Originally Posted by Stuntman G View Post
    atleast you know the problem, you can get repair manuals online for free as pdf's for wiring etc just google it.
