Results 1 to 19 of 19
Thread: Boosted H22A vs H2b
    Norcross
    Default Boosted H22A vs H2b
    Wondering witch setup would be better for boost. First off, not doing anything crazy this is a daily drive.
    H22A with the long gear H series tranny or H2b with a short gear + lsd type r tranny. My goal is around 320-350 whp. Witch would be better for boost?
    lmk your opinions
    Jun 2009
    Southside, ATL
    if i was boosting i would do the h2b but i would find a gsr tranny. The type r tranny i think will be way to short once you start spoolin you will be on the rev limiter every gear. The gsr will ride out alittle more and it's still shorter then the h22 tranny
    Norcross
    i think the h23 tranny is about the same as the gsr so what would the point of going h2b be if its the same gears?
    North Augusta, SC
    Or just leave the h22 transmission in it. Long gears aren't always a bad thing with a turbo.
    Back to being stock and slow
    IA's Pedo-cord tdurr's Avatar
    Fayco
    ^^ he knows.
    Save ur engines!
    Jun 2009
    Southside, ATL
    Quote Originally Posted by j0nbunklah0m View Post
    ya the gear ratios are very similar between the h23 and gsr
    H23A1
    1st - 3.307
    2nd - 1.857
    3rd - 1.320
    4th - 1.034
    5th - 0.812
    Type R
    1st- 3.32
    2nd-2.10
    3rd-1.45
    4th-1.107
    5th-0.848
    GSR
    1st-3.23
    2nd-1.9
    3rd-1.36
    4th-1.03
    5th-0.787
    Jun 2009
    Southside, ATL
    Quote Originally Posted by Motivation View Post
    True just depends on what he wants to do
    Long geared transmission - lower acceleration, higher top speed and mile/hr ( like bonneville salt flats)
    Shorter geared transmission - faster acceleration , lower top speed and mile/hr ( like a rally car)
    Cons of longer gears - people will tell you that you will "stay in boost longer", but that only by the butt dyno, when your acceleration is slower to get to desired speed
    Cons of shorter gears - good acceleration, higher rpm speed at highway driving speeds car goes more quickly into engine load. This means more use of fuel and even less economy than what you had.
    Pros of shorter gears - good acceleration, good for street use to get to speed more quickly. It makes a 1.8 litre act like a 2.5 litre in acceleration rate
    Pros of longer gearing - Bonneville speedway top end over 168 miles/hr. (not like you'll ever see it)
    North Augusta, SC
    Quote Originally Posted by Robinson View Post
    I agree. But, if you are making a good bit of power you also don't want that short of gearing because traction may become more of an issue. He also said he was dailying it. I would prefer (not saying it's best by any means) longer gearing when boosted especially for daily. With stock head, he can't rev (well, he can but wouldn't advise. lol) to an extremely high rpm so that takes away some from the time in boost. Also, depends on the size of turbo. If you have a smaller turbo it will fall on it's face on the top end so shorter gearing would be beneficial, but with a bigger turbo the longer gearing would be nice for spooling. Also, it depends on if the motor is built of not. But, for the op. His HP goals are easy to reach on a stock motor with a .57 trim at around 9lbs. Sleeves are good to around 350, I've been told.
    Jun 2009
    Southside, ATL
    Im glad im all motor lol to much thinking and planning when it comes to turbo's lol
    but if you decide on running the type r you should swap out that 5th gear especially for daily i can tell you 60mph at almost 5000rpm sucks for the highway well my 4.7
    Fayco
    lulz at ur short 5th. im at 75ish at 3k.
    Save ur engines!
    Get a ls tranny!
    Jun 2009
    Southside, ATL
    Quote Originally Posted by tdurr View Post
    i wish i had that lol
    South Side Georgia
    I like GS-R transmission because the gear aren't too short nor too long. Just right.
    resize pic
    F22A1 tranny. 160 in 5th at 6300rpm
    TheMyth
    when i had my gsr turbo teg, wish i had a longer 5th gear - like a LS 5th. i would top out at 150-155mph. it didnt take me very long to tap it out !!
    Soul Crusher RUFFIAN's Avatar
    in your nightmares
    why on earth would you want Boost+short gears good luck with that.
    N/A>>><<<BOOST
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    i will probably end up going to an EP3 transmission in my civic over the 6-speed for the better gearing. right now they are so short that with my power i can't hook to save my life until 4th.
    Berta- I would say I feel your pain, but the K20 6-speed is geared for 180-ish. WAY more than i require lol
    Who knows?
    SOUTHERN SPEED
    macon ga
    h23 and gsr trany are not that close in gearing look at the final drive. All h series tranys are high thats why everybody is going h2b plus the 20percent lose in moving parts which ads to hp on the dyno. As for the hp you are wanting and the money difference and it beind a dailey driver buy a m2b4 thats the lowest geared lsd trany there is for a h ( besides the tyoe s trany which you want find) or a m2a4 same gearing no lsd i promise you will be more then happy with it. About three months ago there was a m2b4 on here forsale for 400 so if you look you can find one reasonable. Later on down the road if you decide its not low enough buy a lower final drive still less then the h2b kit and the bseries trany.
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
    F.O.C.U.S jdmshytyo87's Avatar
    Oct 2009
    cedar bluff, al
    i heard that!!!
