Thread: need help with piston part number
    rockem sohcem robot
    Default need help with piston part number
    i just bought a motor, b16a2, with eagle rods and je pistons, the piston part number is 149213, what kind of compression will this thing make with a b16 head??
    all help will be super repped!!
    "TheCrew"
    Crew member #3!
    just because I came in late I am leaving one two open haha
    Certified Gearhead sang's Avatar
    Nov 2009
    stockbridge
    here ya go man.
    pn#:149213
    B16A1,A2,A3 Si, 81.50mm (.020) Bore, 10.5:1 CR, 5.7cc Dome
    rockem sohcem robot
    yeah thats what i found, i was hoping i was wrong, this is too high for boost, but not quite enough for all motor is it?
    "TheCrew"
    Crew member #3!
    Nov 2009
    stockbridge
    uhh its a little in between. you can possibly go boost, but u cant go doing 20 lbs now lol.
    je doenst have a piston with that model srp does.
    an if thats the case
    Quote Originally Posted by sang View Post
    here ya go man.
    pn#:149213
    sry but your figures are not correct
    http://www.jepistons.com/Catalogs/SR...6a1-a2-a3.aspx
    last on the list
    it will also give a comp of 10.386953889798464:1
    rockem sohcem robot
    well crap, i wanna go heavy NA, so looks like ima need higher compression pistons to run big cams right? like pro2s
    "TheCrew"
    Crew member #3!
    Nov 2009
    stockbridge
    last on the list
    ahh dam ur right. i got the wrong spec's and info. sry about that
    rockem sohcem robot
    so thats like stock compression? the top of these pistons look like this /\
    whats the point if its stockish compression?
    "TheCrew"
    Crew member #3!
    Nov 2009
    stockbridge
    if you wanna go na crazy. id go for a 12.5:1 or something around there
