Thread: Need Car Mech Help!!!
    Rice Rice Vtec
    Default Need Car Mech Help!!!
    i have a 1989 Honda Accord LXI.
    the problem is that it wont go in gear when its started up. but then its not started up itll go in gear with no problems. out of the blue it just did this one day. what can it be?????
    i try putting it in 1st and starting it up and the car will just jump jump jump like its trying to start.
    what does this sounds like? THROW OUT BEARING?, CLUTCH?, SLAVE CYLINDER?
    is this a Cable or hydro tranny?
    95 Civic EX-Traded
    93 Civic CX -Sold
    93 Nissan Altim-Sold
    95 Civic CX- RIGHT NOW!
    barrow county
    check fluid?
    its got a blow dryer jdmDC20's Avatar
    Apr 2010
    L'ville
    if you can get it into gear while the car is off, the problem lies within your disengage mechanism (disregard spelling) the first thing to check is your master/slave cylinder... push the clutch in and have a friend check the movement... if movement is low, check your fluids/bleed... if you bleed it and movemtn is still low... look into replacing your slave cylinder, also look into the seal inside the car for the master cylinder
    if all that is fixed and fine... look into getting a new clutch kit, it'll come with presure plate, clutch disk, bearings... and most OEM replacement clutch kits are affordable
    start at the basics and move up
    Rice Rice Vtec
    check fluid?
    fluids been check. it was low so i added more in about half to fill it up.
    95 Civic EX-Traded
    93 Civic CX -Sold
    Rice Rice Vtec
    Quote Originally Posted by jdmDC20 View Post
    i will check that as soon as i get the car towed to my house.
    95 Civic EX-Traded
    93 Civic CX -Sold
    give me a call and make an apt. im sure i can get you diagnosed.
    barrow county
    tranny fluid? clutch master cylinder
    Rice Rice Vtec
    tranny fluid is good
    95 Civic EX-Traded
    93 Civic CX -Sold
    Rice Rice Vtec
    anything else yall can think of?
    95 Civic EX-Traded
    93 Civic CX -Sold
