Results 1 to 4 of 4
Thread: ◄FS: Eastwood Dual Voltage Powder Coating Gun Brand New!►
    JDM TYTE AnthonyF's Avatar
    Default ◄FS: Eastwood Dual Voltage Powder Coating Gun Brand New!►
    I bought this 2 months ago and never used it. I ran powder through it to make sure everything works. This kit has everything you need to start powder coating today! All you need is a dedicated oven and compressed air. Ideal for hobbies, auto parts tools, crafts and much more. Powder is highly durable and easy to clean up- just sweep up the overspary! The new Dual Voltage system gives you the capability to coat small areas using the Low 15kv setting. Or coat large areas using the High voltage setting 25kv. All you need is a compressed air source (5-10 PSI from a portable tank with a regulator or a compressor) and an electric oven or toaster oven.
    Contains:
    11676 Dual Voltage Hot Coat Powder Coating gun
    Silicone plug assortment
    1/2" High Temp masking tape
    1lb spool of safety wire
    3 empty bottles
    1/2 lb black powder, plus Bonus chip chart
    Plus 2 lbs of Flat black powder
    Paid around $260 for it Brand new, and it is still brand new. $200. No trades.
    -Ant.
    The Carbon Fibered R6
    Privateer Racing!!
    Duluth,Ga
    Damm only if i had a big enough stove....
    30" is plenty to do most jobs. Could always invest in a stand up heater.
    -Ant.
    TTT
    -Ant.
