- F/S: PIII Server System
- Rep Power
- 0
Overview
Used Intel's L440GX+ server board is specifically designed for businesses seeking a highly reliable server solution to meet their business computing needs. Because business critical information requires maximum server up-time, Intel extensively tests and validates all server board components, drivers and widely used server based Operating Systems. With support for up to two Pentium III processor slots and multiple add-in card slots, the L440GX+ server board is flexible enough to meet changing demands as businesses grow. Easy to use server management tools provide businesses additional reliability.
Features
- Supports Dual Pentium III Processors Running at 450-MHz and Up to 1GHz
- 100-MHz System Bus
- Intel 440GX AGP Chipset
- Supports up to 2GB PC100 SDRAM
- 7 Total Slots - 2x 66-MHz PCI, 4x 33-MHz PCI, 1x ISA
- Platform Event Paging Provides Instant Alert Capabilities (Downloadable from the Web)
- Easy to Use Intel Server Control Software for Server Management
- Emergency Management Port for Remote Diagnostics and Management
- Designed for Intel Astor II Server Chassis w/5 x 10Krpm Hot-Swappable LVDS HDD
- Server AT Form Factor
- Integrated (On Board): Adaptec SCSI with Ultra 2 and Ultra-Wide Channel, Intel 82559 LAN, Graphics Controller with 2MB RAM.
Additional Information
To view the Technical Product Specification, visit:
ftp://download.intel.com/support/mot...254151-003.pdf
To view the Product Guide, visit:
ftp://download.intel.com/support/mot...x/72207707.pdf
For other information visit the products support site:
http://support.intel.com/support/mot...server/l440gx/
New ARO-1130U2 SCSI RAID never been open + opened ARO-1130U2 SCSI RAID card extra.
Features:
* RAID Levels Supported:RAID 0, 1
* Cache Memory: Up to 64 MBytes EDO DIMM
* Device Protocol: SCSI Ultra2, Ultra, Fast and Wide
* SCSI Channels: Ultra2 SCSI chip connected to RAIDport III
* Computer bus: 32-bit PCI local bus and RAIDport III socket connector
* Devices per SCSI Channel: Up to 15
* Maximum bus transfer rate to 80MB/sec
http://www.adaptec.com/worldwide/sup...key=ARO-1130U2
Cheetah 36ES - New RMAed Hard Drive, never been opened or used, warranty sill good till Jan 25, 2006
Model Number:ST336706LW
Capacity:37 GB
Speed:10000 rpm
Seek time:5.2 ms avg
Interface:Ultra160 SCSI
http://www.seagate.com/cda/products/...81,346,00.html
Also comes with
Pentium III 550/512/100/2.0V S1 10230317-0369 Used / Tested Working / No heatsink
AMP Terminator Card for dual Slot 1 motherboards. Used for 66/100/133 Mhz Used / Tested Working
Intel EtherExpress PRO/100 LAN Adapter PWA#: 651538-003 Used / Tested Working
Belkin F5U005 1.1 dual port USB Card Used / Tested Working
Array Microsystems, Inc. VideoONE Recorder Used / Tested Working (Will include software on CD)
http://www.array.com/rec-prod.htm
Agere Systems L56xM+S (Mars-2)
http://www.devidal.tv/~chris/winmode...re_L56DMS.html (Will come with original CD)
640 Megs of ECC Non-Reg RAM. Four RAM sticks:
ValueRAM KVR133X72C3/256 Infineon HYB39S128800CT-7.5 Chip
128MB, SYNCH, 100MHz, CL2, ECC, MT18LSDT1672AG-10EC7, 48LC8M8A2 Chip
Two 16X72 (128 Megs x Two Sticks 256 Megs) PC100-22-620, 48LC8M8A2 Chip
SCSI, IDE, Floppy Cables
Two Network Cables
I also have A hotswapable 5.2" Tray. I'll Throw that in for the winner to play with. It's for the SCSI drive, only thing is I don't have the keylock key for it.
All drivers for hardware will be on CD, I'll also have the manual for the Motherboard on it in PDF format, I'll also include the latest BIOS on a floppy Disk in case anything strange happens (which nothing should, just a safety precaution)
Looking at about 250 for everything, PM me if you want to see pics.
- You may not post replies
- You may not edit your posts
Forum Rules
