Results 1 to 14 of 14
Thread: b16 stuck in safe mode
    Senior Member Code-Aye's Avatar
    hahaha
    Default b16 stuck in safe mode
    i have had my b16 for a while now, i was obd0 running a pr3, and my car was stuck only reving to 3.5. so i read some fourms, i then went back and wired my distributer to the ecu. still same problem. so i sucked it up and conveted my car to obd1, i have a p30 ecu, obd1 distributer, and the conversion harness. i am still having the same problem. any ideas of what could be my problem
    hahaha
    I have a brand new distributer.its for crank angle
    vanilla sky.
    limp mode.
    Quote Originally Posted by Pimp_Stick View Post
    huh
    hahaha
    My cel is for crank angle.and my distributer is brand new. So I dont know how im having this problem
    what code are u getting
    I eat my boogers. 00Civic's Avatar
    Apr 2010
    I googled it up....I would just suggest to try and replace the crank angle sensor .....have you done that?
    hahaha
    When I was obd0 code 4, 15, 22. Since i have gone obd1 I need to go get a toggle switch so i can read the codes
    hahaha
    Quote Originally Posted by 00Civic View Post
    The crank angle is in the distributer, and the distributer is brand new
    Apr 2010
    maybe check for exposed or shorted wires? going to the ecu? just an idea
    hahaha
    I cant even tel you how many times I have done that
    Apr 2010
    what about the plugs to the sensor? is it corroded?
    put that jumper in
