Thread: which bearings should i use
    Aug 2009
    Default which bearings should i use
    i have a b18a1 that i am building. it has 8.5:1 srp pistons eagle rods and a balanced crankshaft. i was wondering what bearing size should i use. should i go with standered or have it loose because it is turbo. the horsepower range that am shoting for rightnow is about 310-350 wheel horsepower.
    Flowery Branch, GA
    Measure, measure, measure. Or better yet, take it to a machine shop and let them check it for you and make a recommendation. We run standard on anything under around 400 wheel. Anything over that and we like to open it up a bit.
    ---Mike
    GOT BOOST?
    forsyth
    yeah measure and if you dont know what your doing def take it to the machine shop
    Northwest Georgia
    Standard. Thanks.
    Bearing clearance is the least important clearance to worry about, not saying its not important, but as long as the crank measures consistent and hasn't been turned, standard.
    Build 42% Done ACCORDPRIDE's Avatar
    In a pile a H22 parts
    u have to measure the crank and make sure it is standard or has been turned and get the bearings that fit ur crank- at that hp you jus need some good bearings and put that thing 2gether- imo
    AKA HIZDAWAY
    Forged Performance Sharif@Forged's Avatar
    Marietta, GA
    We use standard most of the time, but putting together an engine without first measuring would be unwise. We run our 1000hp engines with fairly tight clearances. Back in the day, a lot of old-school engine builders would "open it up" for high powered builds.
