I was in need of a GSR head, so I made arrangements to pick up a GSR head from shadowx3. So the Friday before Import Alliance I drove down to Atlanta from North Carolina to meet up with him. Met up with him to see the head and this was what I saw.
(pics are taken after I got it home)
By far, it wasn't the prettiest head. The head was "painted" silver and was flaking, then had teal overspray on it. It was missing studs (no biggie since I had spare intake and exhaust studs) The head had caked up oil and grease in it, but that was expected from a head from 1994. Since the head was going to get taken to the machine shop to get cleaned and resurfaced, I wasn't concerned about cosmetics. So I asked shadowx3 if the head was good, he said it was good. I exchanged money for the head and we went on our ways. (I might add that none of the cosmetic "flaws" were visual in the f/s thread)
Now back in North Carolina,
With all new goodies, you exam them, then you exam them again and again. So I remove the cam caps and cams, then I examined the head closer. I look at the exhaust valve springs. What did I see? Dual valve springs. The only head that comes with stock dual exhaust valve springs are Type R head. So I thought to myself I may had gotten lucky, and got aftermarket valve train (I should of realized this is IA no one get lucky) until I saw the intake valve springs. The intake side had only single valve springs.
So that means the head was taken apart and put back together wrong. That had me kind of concerned. So I examined the head closer. The head actually had dirt in it. Also, the head appeared to have a few valves that were slightly different from the others (these valves had a letter on them while the rest didn't). So that had me concerned slightly more. That's when I sent the seller a pm
I took the head to my local machine shop. The machinist clowned stating that I found the worst head I could find. Then they recommend not using the head until the head is pressure tested and it received a valve job. So I gave them the okay. They told me that the head will be done in a day. So I left the head and went home. I checked my pm and had this.Originally Posted by bigdare23
I respondedOriginally Posted by shadowx3
About a week past, and still no word about the head (I just got a performance valve job done there in Jan and the turn around time was 1 day, so I was kind of concerned). So I went to check on the head. Well the delay was valves. They found four bent valves on the head (2 ex, 2 in). The machinist took one of the bent valves and put it on a mill (I believe that name of the device) and had it spin the valve around at it's stem. and with my own eyes I saw that that valve did not spin perfectly (the head had a slight wobble) proving that it was not straight. So I sent the seller another pmOriginally Posted by bigdare23
responseOriginally Posted by bigdare23
replyOriginally Posted by shadowx3
his replyOriginally Posted by bigdare23
Judging by his last post, this seems like it's not going to get resolved since he stands by his word that the head was in "PERFECT CONDITION". But I noticed that the valve springs were in the wrong position, I seen with my own eyes a valve that wasn't perfectly straight at the head, and judging by the pictures most people wouldn't call that head perfect. He also stated he "cant do nothing about it", I guess I wont get my little $20-$40 (depending on the cost of the valves) I'm asking for 2 valves rather than the money needed for 4 valves.
So buyer's beware when you purchase from this dude, and when you purchase any used head. I would of been pissed if I was looking for a head to resurface and throw on. Luckily, I don't trust many people on here, and always get used parts checked out when I'm not full knowledge on it.
(And before some tries to bash me about purchasing a head that looked like that. First, I wanted a GSR head, and I could not find one in my area. Second, you can't judge a book by it's cover. Because the head was spray painted doesn't mean it had been valves. Paint can easily be cleaned up. Next, since the valve "appeared" to seat correctly, there no way I could of found out the valves were messed up without taking them out the head. Last, with the cams/cam caps I wasn't able to tell if the valve springs were in the right place. )
b series.
