Thread: 92 gsr integra vtec problem
    gsrthriller DustinT2219's Avatar
    Tennessee
    Default 92 gsr integra vtec problem
    well my speed o cable is messed up and i cant see how fast i am going. the check engine light is also on im guessing this is why vtec is not working. need some help
    vanilla sky.
    probably poped out of the tranny,been messing with it lately?gotta have speedo for vtech.
    bad sensor if vtec isnt popping
    Certified Gearhead RHD_Joe's Avatar
    Your speedometer has to work in order for vtec to work..there is your problem. Hope this helps..
    PG+K
    Hamilton, GA
    Check to make sure the cable is all the way in there. Make sure the clip is there to keep the cable in too. If that doesn't help then get a new sensor. I know the sensor is in the cluster on EF's not sure about the DA's try to get the mechanical part first which is on the tranny and if that doesn't work see if the sensor is in your cluster.
    EF'N dirtragz's Avatar
    Jul 2009
    the ham
    Quote Originally Posted by T2KU View Post
    x2
    88 crx hf lsvtec 153hp 117tq mainstream
    You always lose money chasin' hoes, but you never lose hoes chasin' money.
    Quote Originally Posted by Civichatch91 View Post
    I will never cheap out again...I should have known better
