Results 1 to 22 of 22
Thread: This is what happens when you don't take care of your engine.
    Smyrna
    Default This is what happens when you don't take care of your engine.
    We bought this '77 Beetle with a blown engine. This is what happens when you don't keep a close eye on what is going on and make sure everything is tightened to the right torque. This was a completely built 2.2l engine with everything aftermarket. Even engines put together with good parts are crap if you don't know what you are doing.
    We bought this car and engine like this and it will stay this way. Its not even worth rebuilding. So the car is getting another engine.
    Carnage pictures:
    And the driver's side head:
    What's wrong with it? Can't you just bolt it back together? Later, QD.
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    Might need a bit of JB weld to make it stay together.
    Gorilla Glue would work better.
    BUILT NOT BOUGHT .........
    Southside Ridin HATCH
    DAMN!
    ESP
    Mar 2010
    GA 400
    Silly Putty all the way!
    The crack
    Bet that thang run like a sum' bitch
    JJSPEC Racing
    swing it by the shop....we'll tig it up good as new
    -2001 Lexus IS300
    Now THAT'S hella flush...
    West palm beach
    typical vw...
    NO ADVERTISING
    -IA MANAGEMENT
    Smyrna
    Quote Originally Posted by BexSican 408 View Post
    Yeah, hella flush between the valve and the piston.
    typical vw...
    Heh, maybe for the newer ones. You have to be retarded to screw up an aircooled vw engine this badly.
    JJSPEC Racing
    Quote Originally Posted by Jecht View Post
    soooo....Evan put it together?
    -2001 Lexus IS300
    Senior Member pr8yr's Avatar
    omg
    No
    GEEZ.
    Atleast everything is there. I'm still missing 2 rods. They're on the side of I-20 eastbound somewhere.
    Senior Member G.C's Avatar
    Forgot
    goddam.
    :idb:
    Certified Gearhead SeePlusPlus's Avatar
    Jul 2009
    Roswell
    Damn, I'm pulling apart a 79 Kawasaki bike that's been outside for 20+ years and its engine looks mint compared to that pos. Have fun!
    Stang Mod slostang's Avatar
    Southside
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    ...when you have a 2.2L that was created from a 1.6L engine, the material has to come from somewhere. The issue with boring these motors out so big is that there isn't enough material left on the cylinders to prevent this from happening. I don't think this was as much assembly error as an issue with over-revving the piss out of the engine, looks like valve floated, struck the piston breaking it, then shattering the cylinder.
    Who knows?
    Smyrna
    Quote Originally Posted by Identity_Crisis View Post
    To bump a 1.6 to a 2.2, you have to get new cylinder sleeves and a new crank case so they are usually thicker. But you're probably right; Beetles don't have a tach so some people won't know how much is too much.
    Slow&InControl! LokiSays's Avatar
    Fire in the Hole!
    live above the limit
    Feb 2010
    lithonia,ga
    lol two words 'magnum steel'
