Results 1 to 20 of 20
Thread: car wont start
    JDM-EJ1 shadowx3's Avatar
    G-County
    Default car wont start
    i have a civic and i was drivin and all of the sudden it turn off it had poped the fuel pump fuse so i replace it and it poped it again so i put a new one and now it doesnt pop but i dont hear the fuel pump turn on and on the main relpy i hear a shortage inside of it i changed it and it does the same thing can anybody help meand also my h.i.ds keep blinking so idk?
    Projects
    check the car for any CEL also a short some where or bad ground.
    Also check the ecu it maybe be causing it to short out.
    Don't put a fuse back in if it keeps blowing you don't want a fire.
    revolution big mac's Avatar
    hmmm it sounds like something is shorting out somewhere. the same thing happended to by buddys srt4 with a wire that shorted out near the head. it kept on blowing fuel pump fuses. chech the wires around the fuel pump area. bc it doesnt sound like it could be alternator or battery
    dam it jay you fucking beat me to it!!!!!!
    Projects
    Quote Originally Posted by big mac View Post
    G-County
    i checked all my grounds but nothing happens why is it that i hear a shortage in the main rely the fuse fuel pump wont pop any more but the fuel pump dnt turn on???????
    Projects
    Quote Originally Posted by shadowx3 View Post
    How are you hearing or what sound is the relay making to make you think its shorting out ?
    i think you since you kept on trying to put in fuses you might of burnt something else which in turn is now making the relay go out. make sure you check all around the engine bay at all the wires.
    also try pm to barefoot is is a wireing guru and would prob be of more help.
    G-County
    the wires that go to the main rely go hot and burnt the noise am hearin is i turn the key where my dash lights go on and i get close to the main rely and i hear a vibarting noise inside of it
    Projects
    it should just click/buzz a sec but yeah swap out the relay first and go from there...
    Best to find a friend or someone who wont mind if you test theirs.
    you say hids blinking also its more like wires or harness.
    G-County
    but i already try two of them and does the same thing tho dam idk
    thats the bad thing about putting fuses in over and over again if it is burning them, more than likly you burned something in the harness. but replace the relay and make sure you check ALL the fuses under dash and hood before you try to start it again
    Projects
    Find a ecu next and if it still does it with a different relay then its gotta be wires i wouldn't think a bad ground would make wires get hot but idk.
    they got hot in my buddys srt. but then again they may not in a civic. i dont think anything inside of the ecu might of burned but doesnt hurt anything to pop it open and see
    G-County
    the fuse wnt pop any more n fuel pump dnt work but i'll try a different ecu but i dnt think thats the problem the wire got hot and kinda got burnt
    Projects
    It may be to late to check now after you tried a few times but unplug the fuel pump and turn switch on see if the harness gets hot or blows a fuse.
    This will rule out a bad or shorting fuel pump.
    well good luck man and i hope you get everthing resolve. let me know if you need anymore help
    G-County
    well i let yall know tomorro what happens thanks for the help
    this a classic short. easy fix with the right tools and know how. hint hint hint.
    Southside Ridin HATCH
    Put power to the Fuel pump.. See if it comes on.. If it doesnt you probly burnt it up...
    If it does...You have burnt some wires somewhere.... you ALSO said you KNOW were the burnt wires are????
    What chassis civic?
