Results 1 to 5 of 5
Thread: Snap On 1/2" Impact Wrench w/Socket Set
    Norcross
    Default Snap On 1/2" Impact Wrench w/Socket Set
    Selling Snap On Impact Wrench 1/2" Drive MG725 with Socket Set [BRAND NEW] $600 FIRM
    Impact Wrench Specs:
    MG725 Features:
    • Unit delivers an outstanding 1,190 ft. lb. (1,613 N•m) of Bolt Break Away Torque!
    • 810 ft. lb. (1,094 N•m) of Recommended Working Torque
    • One piece precision machined magnesium housing yields an extremely durable lightweight, balanced unit with minimal vibration. Superior control with less user fatigue and longer tool life.
    • 8 vane rotor provides faster motor start up and greater performance with more torque.
    • Single chamber motor provides greater power and speed to remove stubborn bolts.
    • Muffler kit reduces noise for quiet performance. Work longer with less auditory strain.
    • Patented cushion grip ribbed handle cover resists most shop chemicals and is easily field replaced. Helps insulate tool from cold and reduces vibration.
    • Patented tip valve trigger provides increased air flow and greater tool control.
    • Twin hammer impact mechanism is durable and hard hitting. Fewer parts, less down time.
    • Sealed in oil bath lubrication with Red Line Synthetic Oil always keeps impact mechanism lubricated for less wear.
    • Slim style nose is ideal for working in restricted access areas.
    • Anvil stop feature - Anvil stops when trigger is released. Prevents anvil from throwing nuts and sockets.
    • Cushion grip trigger button delivers improved comfort and control.
    • 2 Year Warranty.
    Sockets:
    Standard: 3/8" - 1"
    Metric: 10mm - 24mm
    CASH ONLY PLEASE! Scammers & Low Ballers Will Be Ignored!
    contact me thru text 678-467-9590
    IA Member googoo's Avatar
    Dec 2008
    tyrone
    damn good deal man,glws
    Senior Member Patterson's Avatar
    Summerville
    those guns are no joke. i bought one some years ago. it has taken a beating even with heavy equipment work for 3 years and never a problem. G/L buyer will be happy for sure
    DC5-R
    Gwinett
    bump for a good impact, I have the same one at work with the same set. Although $600 is pretty much the price that you can get it off the truck.
    I do OBD1 Emissions blue94eg6's Avatar
    Dec 2008
    very good impact you got here homie, i myself own snap on tools too bump it!!!
