Results 1 to 10 of 10
Thread: ek swap
    Default ek swap
    i might get a 97 civic coupe wit a blown engine i was thinkin bout swappin da engine maybe h22 or b series i was wondering if anyone know around how much dat goes for imma do all the work but also wat parts i would need like engine ecu motor mounts wire harness i heard u need new axles if u put a h22 on it and the difference with a b series if i can use the same tranny do i need any custom mounts or hardware i should know bout let me no if uve done one b4
    i was thinkin a b18 or b20 wats da difference n difference in power in the car n engine also comparin the h22 (all 3 which is da best choice) handling/ performance any info u no will help
    North Augusta, SC
    I have a guy that has all the h22 parts you want for a decent price. Personally, my h22 and the lsd trans was $2690+ shipping, but that was in 2006. You can get them cheaper if you buy them from someone personally. Google is gonna be your best friend to see which motor you like the most. I enjoy the h22, it has a decent amount of torque, for a Honda. What are your plans for the car? Yes, you have to change the axles with an h22, or, you could do an H2B and keep the b series axles.
    Back to being stock and slow
    How much power do you want to end up with? How much money do you have? How much experience with motor swaps do you have?
    im not lookin to get crazy power right now im a tech so i no i can do it just wanna make it easier n research it i have an 01 prelude i just got n like da power from dat engine but itll b my daily driver prob drop it n make it look nice but just dont want the stock d16y8 i have now on my sedan same year oi might have like 1000-1500 but right now i just wanna put it in n make it run since itll b my daily driver later ill make it faster doin other things to it i dont mind the stock h22 for right now
    A B-series swap is gonna be easier if you can't weld. If you get the right parts, it can bolt in. Whereas an H-swap is going to require grinding and/or welding. There are companies like hasport that make the adapter engine mounts, but the H engines use cables for shifting. The B and D series use mechanical linkage. If you want just plain horsepower, consider a turbocharged D-series, because that can be done for quite a lot cheaper, and there does exist a factory D-series transmission with an LSD.
    OP, I would definitely stick to a B series since the H22 will require some custom work to fit properly. I would go for a B18c1, or a B18b. Skip the B16, don;t end up paying like $2.5K for a swap and only gaining 40 hp/7lb. tq.
    +1 to the LSD D series trans.
    COMPLETS SET OF 1996-2000 H22 AND F SERIES MOTOR MOUNTS FOR CIVIC SWAP
    2 MOUNTING BRACKET
    3 MOTOR MOUNTS
    REPLACEMENT MOTOR MOUNT KIT FOR H22 and F SERIES ENGINES
    CAPABLE OF HANDLING UP TO 700WHP AND COMES WITH MANUFACTURER LIFETIME WARRANTY
    NO CUTTING OR WELDING REQUIRED.
    LEAVES ADEQUATE HOOD AND POWER STEERING CLEARANCE.
    thats what it said on the page
    but if i get the d16y8 n turbo it i still have to buy the engine n then turbo it wher im thinkin it as i could just drop in the b18 n ride which is what i thought would b cheaper but im not sure bout tat
    North Augusta, SC
    My H22 was put in and nothing was cut... and no expensive kit was bought for the swap. It's a pain when ya work on things. (part of chasis is in the way when pulling transmission out, etc) it takes a little more patience
    i think i might get the b18 ijust cuz its cheaper n less parts i have to buy like tranny n axles for da h22 whereas as i think i might just b able to drop the b18 n just need da ecu n wirin harness i want a b18c but cant really find one n thers a guy that said he can get me a b18b full swap for 1200 so think dats not a bad deal
