Results 1 to 5 of 5
Thread: FS: '04 KTM 625 Supermoto $2k
    Default FS: '04 KTM 625 Supermoto $2k
    FOR SALE
    KTM Supermoto
    Make: KTM
    Model: 625 SMC
    Year: 2004
    Mileage: 20,745 miles
    Price: $2000 read the good/bad section
    Contact: 706-244-4210, Brad
    Mod List:
    Motor
    Akrapovic slip on(shortened),
    Uni airfilter
    KTM hard parts airbox cover.
    Dyno tuned, so it was perfect jetting wise.
    Suspension
    Suspension work done by G.M.D. It has RaceTech springs & emulators in the front forks along with new seals, oil, etc. The rear shock was rebuilt less than 1k ago, and they did a piston to bladder reservoir conversion(for better motion and easy service) from RaceTech. It also has a Eibach rear spring, new seals fluid, etc.
    Etc
    Motomaster front brake rotor
    Fastway handguards with a damper mount.
    '08 EXC front headlight and mask
    White plastics
    Edge rear tail light
    Custom rear fender- custom fiberglass piece that my dad made.
    Extras
    New rear sprocket
    New EBC front pads
    Misc Orange plastics
    Extra seat pan w/ foam
    Gripper seat cover
    Repair manual, misc. ktm paperwork along with oil change tools
    The Good: One of the best supermotos you can buy IMO. Factory hyd. clutch, Brembo brakes, rear cush drive, inverted forks, 5" rear wheel, electric start & kick start, factory speedo w/ tons of options.
    The Bad: Engine has developed what seems to be rod knock, and I don't have the funds to rebuild it right now.
    PICTURES
    Ahhhhhhhhhh...any idea how much a new motor/rebuild is?
    Hiawassee, GA
    If you caught it early enough rod bearings are reasonable, finding someone to split the cases and press them on and such would be the expensive part.
    -Zach-
    1987 Toyota Pickup - Toy
    Looking at around $1500 with all new stuff, crank, etc. Might be cheaper depending what's still good.
    ///M :) wannab20hatch's Avatar
    Gainesville
    you got pm man.
