Results 1 to 21 of 21
Thread: air fuel ratio gauge not bouncing why?
    Certified Gearhead dc5k20's Avatar
    Default air fuel ratio gauge not bouncing why?
    i installl an air fuel ratio gauge on my rsx and it wont bounce around just stay at full rich even when the car is running for like 10min! cant be a bad 02 sensor cause just bough new for acura dealer! i hook up red to positive battery/black to ground/ white to parking light/and the green to white wire on 02 sensor surpose to be signal sensor wire! lmk if ya have any idea?
    Titties!!!
    Quote Originally Posted by dc5k20 View Post
    it's the connection somehow, i know on my si the white is the o2 wire and sometines the connector used to tap into it will get pulled out by a passenger and it goes to rich and does not move, but i fixed that problem recently. also make sure you did not cross up the light wire to the o2 wire, have a cobalt so mine is 3 wires, check all you connections and make sure they are good and no wires are crossed.
    TougeTougeTouge!
    Buford
    what brand did you use?
    http://checksix-crew.blogspot.com
    Type X S13 RB25 Swapped
    Check Six BRAHHHHH!
    Alpharetta, Ga
    should have just bought a wide band. your factory is only to show you from like 14.2 to 15.2. which is basically nothing. unless its a wide band, but that gauge is just about worthless for any information that will save your motor.
    The G Spot Hero
    cant really afford a wide band gauge.i got the cheap shit for autozone lol! to me i dont really care if it read right! as long as it freakin bouncing around than im cool with that! but this shit stay rich and dont bounce let me see what happen!
    Titties!!!
    Quote Originally Posted by DirtyMechanic View Post
    only thing the guage itself it gonna read ok it wide open throttle but nothing in between. i got mine just to fill a hole in the cluster that came on my car and someday would love a wideband setup but a chip and tune for me would come first.
    Alpharetta, Ga
    might need to calibrate it too...
    The G Spot Hero
    Titties!!!
    the a/f gauge, how do you do that, i try learning all i can for sure please explain.
    Alpharetta, Ga
    Quote Originally Posted by preferredduck View Post
    the one i had to do forever ago was a pos autozone one too. usually its just turn the car on cold. and let it sit while you press a button or something. its called reading the directions.
    The G Spot Hero
    i got that shit work!!!!
    Alpharetta, Ga
    what? english
    The G Spot Hero
    Titties!!!
    i have an autometer so no button pushing, mine works at startup but i read the directions to wire it up for sure
    so what was the problem anyways.
    Oct 2003
    You installed the wrong A/F gauge on car. RSX's from the factory comes with air fuel/lambda sensors (instead of regular O2 sensors) for the front which makes a maximum of 5v, so the a/f gauge you bought was for a car that will produce a maximum of 1.25v which as a result is pegging out your gauge. Buy the right gauge and curb your cheapness, sir.
    lol then its working fine.
    its work now! because i relocated to the secondary 02 sensor! i though primary 02 sensor was the one that you hook up to that why i hook up to my primary.that why it didnt bounce! so i try it on the secondary 02 and it bounce all over!!! i know my car's running good just need it for look!!! will any rsx ower out there secondary is the one!!
    Alpharetta, Ga
    wow epic fail. the secondary is the one that monitors the cats or cat. not what the engine is exhausting.
    The G Spot Hero
    Alpharetta, Ga
    Quote Originally Posted by blackshine007 View Post
    this
    The G Spot Hero
    i have the kiddracing header! dont have a cat.
    Alpharetta, Ga
    *sigh* ok great doesnt matter, the second 02 sensor is meant to monitor the cat if its working or not. and since you dont have any. then its not monitoring anything.
    The G Spot Hero
    Titties!!!
    amen, i have one on the header and one on the cat that monitors the cat and function, mine is on the primary o2 atleast but thats crazy yo!!!
    rollin 91 da egpower904's Avatar
    Dallas, GA
    wow epic fail.
    <epic win> DirtyMechanic </epic win>
    DA SQUAD MEMBER #70
    91 da/95 gsr/boosted/awaits tune....
