Results 1 to 35 of 35
Thread: RB20 240 help please
    Apr 2010
    Default RB20 240 help please
    I just bought a 89 RB20 swapped 240...when I bought it, I had to pop the clutch to start it, it died on me, I replaced the battery, turns on and it smokes black smoke, and then it shuts off in like 10 seconds, or if you give it gas, it turns off right away. what can it be?
    West palm beach
    Quote Originally Posted by GreenDB7 View Post
    need a lot more info then it smokes for ten seconds and dies. Could be a number of things....
    NO ADVERTISING
    -IA MANAGEMENT
    TougeTougeTouge!
    Buford
    lol man fuck RB's
    http://checksix-crew.blogspot.com
    Type X S13 RB25 Swapped
    Check Six BRAHHHHH!
    Apr 2010
    If I step on the gas, it shuts off right away. It smokes black, white and blue smoke.
    West palm beach
    lol, sounds like you have major problems, have someone look at it for you...
    NO ADVERTISING
    -IA MANAGEMENT
    Apr 2010
    Man it was running perfectly fine, I just got the car too, like a few hours ago. Didn't even hit boost.
    West palm beach
    damn, that does suck. But seriously man, have someone look at it that you trust, before you wast anymore money...
    NO ADVERTISING
    -IA MANAGEMENT
    TougeTougeTouge!
    Buford
    sounds like a misfire to me. pull your spark plugs, check for vacuum leak, check to see if your maf is plugged up, try another ecu. etc.
    Check Six BRAHHHHH!
    Apr 2010
    Really stupid question, but where is the MAF on a rb20? first non honda..lol. i think its the maf. It sounds like it releases alot of air when I start it up.
    Apr 2010
    anyone?
    Norcross
    should be near the air filter
    TougeTougeTouge!
    Buford
    lmao, i said check for vacuum leaks. that should be your culprit. also check to see if you fouled any plugs.
    Check Six BRAHHHHH!
    Apr 2010
    Quote Originally Posted by ZenkiCam View Post
    http://i42.tinypic.com/huhbvs.jpg
    oil catch can, correct? The lines won't stay on it, they fall off everytime, and its leaking. the car will start up, smoke and shuts off.
    Apr 2010
    Someone point out the MAF to me, lol...
    http://i41.tinypic.com/vyta3d.jpg
    423 KING
    Chattanooga, TN
    it may be bc your a fucking homo
    18x9 +24 18x10+22
    RedHenRacing #02 Stuntman G's Avatar
    Jul 2009
    You mean VTAK, right? The only boost I ever hit comes from a set of cables.
    INSIGHTFUL DIALOGUE ANALYSIS: Actually, Hector, that is not what we call valet parking. Valet parking is where someone parks your car for you. You just pulled your car up to the front of the store and got out. We just call that parking.
    I MAKE THESE
    TougeTougeTouge!
    Buford
    it should be off the intake between the turbo inlet and the intake. if there is no maf there it is either on the intercooler piping, or lacking one.
    a maf looks like this...
    Check Six BRAHHHHH!
    Jul 2009
    To be a little more helpful, I would suggest this guy's suggestion ^^
    I MAKE THESE
    TougeTougeTouge!
    Buford
    Edit* double post. sorry.
    Check Six BRAHHHHH!
    Apr 2010
    I don't one of those in my engine bay...lol.
    Will a bad/dirty MAF cause smoking and cause it to turn off?
    TougeTougeTouge!
    Buford
    better yet, if you want to save your self some headaches and get it fixed real quick, take it to Dave at Pro Auto Care in Marietta, he got my RB running right in 30 minutes. It wasnt firing on all cylinders and he got it running like a champ.
    here is his info.
    Dave @ Pro Auto Care
    770-980-0033
    1895 Airport Industrial Pk Dr
    Marietta, GA 30060
    Monday-Friday 8am-6pm
    Check Six BRAHHHHH!
    TougeTougeTouge!
    Buford
    LOL well if there isnt a maf on your car then that is the reason its not running right, unless you have an aftermarket ECU tuned with MAP... what ecu are you on..?
    more specifically what 240 dumbass did you buy that car from?
    Check Six BRAHHHHH!
    Apr 2010
    It's got a greddy blue emmange for tuning, idk what ecu.
    ^^this guy loves you jdm-civic's Avatar
    the sky
    from the pic it looks to not have a MAF
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    TougeTougeTouge!
    Buford
    ok, so more than likely you are using a map sensor with the emanage, dude just call dave and set up an appt and i promise you he will have your car fixed within an hour.
    Check Six BRAHHHHH!
    Apr 2010
    I'm gonna clean the MAF, if it doesn't fix it, I'm gonna talk to the guy I got it from and trade back cars. How much does dave charge? I'm not looking to put much money into this piece of shit.
    Apr 2010
    If I don't have a MAF, if i'm running a map sensor, what is the problem them?
    TougeTougeTouge!
    Buford
    lol. well that gets rid of one variable... check for vacuum leaks, pull the plugs to see if you fouled any, is it running on stock injectors? has the car been tuned?
    Check Six BRAHHHHH!
    Apr 2010
    not stock injectors, 900cc, i think. And yeah its been tuned.
    TougeTougeTouge!
    Buford
    900cc....? yes, definitely see if you fouled a plug LMAO.
    Check Six BRAHHHHH!
    Apr 2010
    Thats what he told me, lol. You think it'll be fine if I put stock injectors on it? It's a basically stock RB20, different turbo, 15psi, blitz BOV
    Apr 2010
    So I should put stock injectors in it, and new plugs?
    TougeTougeTouge!
    Buford
    DUDE. you should listen to what i said and call dave the RB guru at pro auto care...
    Check Six BRAHHHHH!
    Apr 2010
    http://i40.tinypic.com/5af1ah.jpg
    Do the seals on the turbo look bad?
    TougeTougeTouge!
    Buford
    the seals are internal on turbos theres no way just to look at one and tell.
    dude i hate to say it but it looks like you got your self into something that you are not ready for yet. do your homework on RB engines please.
    Check Six BRAHHHHH!
