Thread: 4AGE (Toyota guru's needed)
    Middle, Ga
    Default 4AGE (Toyota guru's needed)
    Which would be a better platform for boost? The 4AGE Black top or Silver top? Don't know much about Toyota's but I think I remember hearing something about compression being a difference with the two.
    Toyota guru's...
    Which would be a better swap for an ae86.. The 4AGE or 4AGZE?
    It would be a sr5 to GT-S conversion so would the GT-S harness work with any of those motors?
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Middle, Ga
    Nothing? Guess I should have put in Old School section.
    "Damn, Its Tyler"
    20V silver or black?
    ESP
    Mar 2010
    GA 400
    Well lets see; the Black tops (95+) have a higher compression; 11.1:1 to be exact. Compared to the silvers (90-95) having a 10.3-10.5:1 ratio. Another difference is the valve numbers, 90-91 only had 4 valves per cylinder, but the 91+ have 5 per making 20.
    Middle, Ga
    Quote Originally Posted by tK FuRy View Post
    What all would I have to do to make a 95+ fit in the ae86? Would it be any different from swapping an older 4age?
    "Damn, Its Tyler"
    OSJC driftyboy's Avatar
    Cartersville, GA
    Quote Originally Posted by NVM View Post
    Toyota guru's...
    If you're just looking for boost, the 4AGZE is definitely your best bet. Plenty of power and if you need more just get a pulley kit, or slap a turbo on it.
    Canton
    If I recall correctly the 4agze handles boost nicely but you have to run all the components ( ie; Alternator/ ps pump/ ect) specific to that engine, IIRC. I will be boosting my 4age in my corolla and don't expect mush in the way of problems.
    Try not. Do or Do not.
