Results 1 to 4 of 4
Thread: converting obd0 to obd1/ef hatch
    IA Member project_sohc's Avatar
    Sep 2009
    Jackson, Ga
    Default converting obd0 to obd1/ef hatch
    whats up guys/gals. fixin to swap a d16z6 into my ef hatch but was wanting to know what i will need for the conversion. i have the full swap but i have heard that i will need a jumper harness. if anyone has any input pm me. thanks I.A.
    mcdonough
    pmed sir
    Certified Gearhead ThEGrNGoBLiN's Avatar
    http://www.boomslang.us/obd0_1.pdf ...that should help you out bruh!
    Titties!!!
    don't forget if your ef only has 2 injectors you need an injector relay box and need it wired in so all 4 injectors will work. you will need the conversion harness, i'm not sure if you can use the mounts from the ef motor on the z6 or if they will drop in. also a p28 ecu and if you are using a tranny off a z6 you would need a cable to hydro tranny kit or just use a cable si tranny if you can find one. i'll see if i can find a write up for you.
