Results 1 to 3 of 3
Thread: Bleeding Cooling System on e39 540i
    f-ckouttahere. PROŽ's Avatar
    Unhappy Bleeding Cooling System on e39 540i
    i have a couple somewhat nooooooobish questions.
    This morning I replaced my upper radiator hose.
    After replacing it, I filled the radiator to the top with anti-freeze, but then i later learned that the dipstick under the radiator cap should be flush with the opening (well at least thats what something i read said in another forum).
    Is putting too much antifreeze in bad?
    How do I know if I put too much coolant in?
    Also, how do I bleed the system completely of air?
    I looked at a couple of forums, but the information seemed contradictory, and now I'm confused. (maybe i was just tired when i read it all)
    so this is where im at:
    the radiator is full, and there are no more bubbles coming out of the bleeder screw. am i fine?
    thanks
    Southside Ridin HATCH
    Should be fine if there are NO more bubbles... Drive around for test drive. make sure everything is correct.
    Love Life
    Alpharetta
    You bled at the radiator AND the thermostat? I spent about 2 hours completely bleeding one like yours a few weeks ago.
    They can take a LONG time to bleed completely. Very intricate cooling system...
