Thread: Running weird after tune up...
    L'ville / Gwinnett
    Default Running weird after tune up...
    OK, once again we have a JDM ZC motor (D16A6) swapped into my 93 hatch.
    My dizzy went out over the weekend so I put in a new one along with cap, rotor, and plugs. I also swapped in a set of 180 injectors for the 230s that came with the motor because the car had been running rich and I suspected the P05 ecu in the car was causing the larger injectors to pulse too long.....
    So now, the car has NO POWER from 0-2500 RPM. At 2500 it almost feels like a VTEC hit and the car becomes its normal self again...
    u got the firing order right
    L'ville / Gwinnett
    Yep, the firing order is right... I'm almost starting to think I might be a tooth off from when I did the timing belt.
    it might be.
    L'ville / Gwinnett
    Timing was spot on. Put the 230 injectors back in and life is good...
