Ok folks, I'm trying to clean the garage out before I move in May. I've got a lot of things that I have no need for.
So on to the stuff!
CA18DET timing cover set - $30.00 I have 4 sets.
CA18DET coil pack covers - $10.00/ea Again, I've got too many of these laying around.
CA18DET mass air flow meter - $80.00 Pulled off my car, going N62 so I no longer need this.
KA24E mass air flow meters - $30.00/ea
SR20DET O2 housing - $10.00/ea, CA18 O2 SENSOR IS NOT included!
SR20DET OEM intake tube - $20.00
T2x inlet/outlet pipes, MAF-to-filter adapter plates - $10.00/ea
KA24E starter - $50.00
KA24E alternator - $50.00
XTD 12lb flyhweel for CA18DET - $150.00, THESE GO FOR $180+ on eBay, brand new in the box and includes dowel pins.
CA18DET ECU - $100.00/ea. Unmodified, no aftermarket chip.
T3/T04E .57 trim - $150.00. Been on one car for roughly 50 miles according to previous owner, who I trust. Internally gated, but includes a 5 bolt flange that will nullify that. Also includes a 5 bolt flange that converts to a v-band. ZERO SHAFT PLAY.
S13 tie rod set - $20.00, recommend new outers.
OEM S14 SR20 T28 - $500.00, includes 10psi HKS wastegate actuator ($100 new, currently attached) and I'll also include the factory actuator. Minimal shaft play, about what's expected for a solid, good used turbo.
38mm wastegate, unknown brand - $50.00
OEM CA18DET injectors - $50.00 for the set. 370cc, top fed.
As far as payment and contact info is concerned, PM ME or reply to this thread. Once arrangements are set up through PM's, we'll exchange contact info. I DO NOT take Paypal, and these items are cheap so cash is preferred upon meeting.
