Results 1 to 10 of 10
Thread: Vacuum source. butterfly?
    Norcross
    Default Vacuum source. butterfly?
    JDM b16a. Not sure where this hooks up to. but it idles better when blocked off..?
    -0404101127a_223065-jpeg
    Norcross
    is it ok to just block it off?
    That hooks to the intake (air filter arm) right next to the throttle dashpot vac. hose.
    I'm not real clear on why that bypass is there- it appears that if it senses a vacuum in the intake arm(or maybe a differential between before/after the throttle plate?) it opens to allow some air to bypass the butterfly, raising the idle a little bit. Note that its big hose is pulling air from the EACV supply passage and routing it directly to the plenum. I just went out in the yard and looked at 9 different manifolds. Half have it, half don't.
    Fwiw, my b16a doesn't have one. It's the early version with the 2 O2 sensors.
    With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion. - Steven Weinberg
    Quote Originally Posted by j0nbunklah0m View Post
    Yes, but if you want to be sure it's not messing with your idle, block off the big hose on both ends.
    Southside Ridin HATCH
    You can take that BS off man..
    Norcross
    aye bro .:Stirfry:.'s Avatar
    yea take it off. you can find a lil block off plate on ebay for that.
    ATL DAsquad Member #9
    ^^this guy loves you jdm-civic's Avatar
    the sky
    thats for the automatic tranny b16's. it slows the throttle from closing too fast, its useless now so take it off and get a adapter plate for it or just cap the opening
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    Senior Member G.C's Avatar
    Forgot
    dumb.
    :idb:
    that is for and automatic. just block it off or get rid of it.
