Need a little help....
ive got everything plugged in secured but its not working!!
REPS for any advise what am i doing wrong...
fuse?
wen i installed my i had to do this
Mine work with the car turned off but when it's running they strobe. UGH
Got a MINI? Don't talk to me.
FUCK your FADS
turns out the hid wouldnt light bc of corrosion in the headlight socket... gotta replace that and im good...
got em on!!!! BUUTTTT MY RIGHT ONE IS FLICKERING NOW!!! the left one is perfect tho!!! how do i fix!?!?!? REPS 4 ADVISE
did you pee on it? that solves EVERYTHING!!!
Originally Posted by TheDrunkScotsman
also i dont have the ballast mounted....
ahhh so it just plugged right up? if you just got both sockets replaced it sounds like there are a couple wires in the wrong place. Double check and make sure they are where they need to be and connected correctly. If they are...might wanna look into getting your HID kit replaced.
Yeah mine are strobing and I'm hoping this relay I bought works! Gah I hope so! I want these! lol
FUCK your FADS
If they are strobing (both at once), there is not enough current to support the draw at startup. You must relay it then.
ya just buy a relay if they strobe mine did that or just turned off randomly till i got the relay
ifs its an H4 kit single Xenon than you should have 2 wires. you said one is on and one flickers. you should have have a 3 prong connector. the top is a ground and the left is for high beam and right if for low beam. you do not mirror the plugs. the right is the low on both sides. So if it flickers that means you have the wire in the high beam side. put the wire in the other side and it should work. I just went through this with my buddies car. he had the same problem you have.
I have a Turd in my pocket.
