Results 1 to 4 of 4
Thread: Ecu not registering
    Jan 2010
    gwinnett, Ga
    Default Ecu not registering
    ok i have a big problem and need somehelp.
    Ok i recently replaced myknock sensor and every thing was working fine but then my check engine light came back on. So i took it to autozone so they could read the code. After that i found out i had a bad tps ( throttle position sensor) So i just replaced that about a week ago. Idrove it about 200 miles and no check engine light came on. So i took my car to the emmisions place to get tested but when he hooked it up to the machine every thiing was registering not ready could this mean i have a bad ecu?
    del sol? 94_teg_ls's Avatar
    no it means its not ready give it a couple hundred more miles
    Titties!!!
    a bad ecu and the car usually won't start, but it could be on the way going bad but i don't know if it's all or none on the ecu's i mean it is electronics.
    Jan 2010
    gwinnett, Ga
    Ok Thanks
