Thread: 2004 Mystichrome Cobra Vert, 2.3L Whipple, 36K miles, GA
    BOOST3N tmoney11286's Avatar
    Midtown
    Default 2004 Mystichrome Cobra Vert, 2.3L Whipple, 36K miles, GA
    For Sale: 2004 Ford Mustang Cobra Convertible
    Color: Mystichrome
    Mileage: 36,xxx
    VIN: 1FAFP49Y94F163342
    Price: $25,000
    I purchased this car last month off of SVTP. It is an AWESOME car, but it isn't right for me because I want to do some road racing this year.
    Modifications:
    Whipple with 3.0 Upper / Stock Lower 17 / 18lbs
    Made 620 / 580
    Polished Whipple 2.3 1st Gen with coated rotor upgrade aqnd polished mounting plate
    RR Pullies / Ideler BF Ideler bracket
    (RR Tensioner but not installed)
    Stock Heads / Bottom End
    EGR Delete
    Oil Seperator
    Fuel:
    60lb Seimens Injectors / Harness adaptors
    KB BAP / Wire Upgrade
    Gas Tank PPRV delete
    Intake:
    TB Stock Steig Ported / Polished
    C&L Elbow / Mas Air Housing and Believe the Filter Housing is C&L as well
    K&N Filter
    MAF SCT 2800
    Tuning:
    SCT X-Cal2 Tuner - 3 Tunes by HBH. Car was initially tuned by John Lund prior to further upgrades.
    Exhaust:
    Bassani Ceramic Coated Mid Length Headers, Catted X-Pipe, and Catback
    Suspension:
    MM CC Plates - Chrome
    H&R Race Springs
    Tokico D-Spec Fully adjustable shocks / struts
    FLSFC - MM
    PA Racing K-Member
    BF Diff Brace
    Cooling:
    AFCO Professional HE
    Polished Canton PS and Coolant Tank
    Polished P-Fab IC Tank
    LDC Cooling Mod
    Other:
    Polished Fuse Box Cover
    Polished Oil Cap
    Polished Fore Coil Covers
    UPR Stainless Bumper Inserts
    Mystichrome Painted Valve Covers
    CDC Lightbar W/Brake Light
    AFS 18" 03 / 04 Rims with KDW2's 275 35 18 on front and 295 35 18's on rear 10.5" rim
    Spec 3 Plus Clutch
    Fidanza Flywheel
    26 Spline Liberty Input Shaft
    Fore Clutch Adjuster
    Quadrant is Fore or UPR (forget)
    Autometer Fuel & Boost Guage
    Steering wheel and Guage cluster Pod
    Innovate Wide Band
    20% Tint
    MGW Shifter - Red Handle
    Spare quart of Mystichrome paint
    California Car Cover
    Viper alarm with window activation
    Car also has brand new Powerslot front rotors and Motorcraft front pads. It also has a Reichard Racing Billet belt tensioner that is uninstalled that will go with it. Also, I have a few boxes of stock parts that will go with it as well including the stock springs. Car also has all paperwork for maintenance, modification, and instruction, as well as the original purchase information from SVT and from the dealer.
    Negatives: The paint is in great condition but the front fascia has a number of nicks from being driven, no dents anywhere on the car. The hood has 3 hairline scrapes on it that are in the last pictures of the first post. The Wideband was throwing a code from a bad O2 sensor when I purchased it. I replaced the 02 sensor and the wideband isn't throwing a code but it needs to be reset because it currently doesn't read anything.
    Contact Info:
    Email: [email protected]
    Phone: 404-234-0535 (name is Terrell)
    Car is located in Atlanta, GA
    Pics:
    ///M6
    Midtown
    ///M6
    Midtown
    My Autocheck from last month when I purchased:
    The AutoCheck Score is a summary of your vehicle's history, letting you compare vehicles with ease.
    About this vehicle's AutoCheck Score
    This vehicle qualifies for Buyback Protection
    buybackSafeguard your investment with AutoCheck Buyback Protection, which reduces the risk in buying a used vehicle.
    About Buyback Protection
    Year : 2004
    Make : Ford
    Model: Mustang Cobra
    Style/Body: Convertible 2D
    Class: Sport Car - Touring
    Engine: 4.6L V8 EFI
    Country of Assembly: United States
    Vehicle Age: 6 year(s)
    Calculated Owners: 2
    Calculated Accidents: 0
    Last Reported
    Odometer Reading: 6,050
    Section summaries
    The vehicle identification number you submitted has been analyzed and summary information on your car is shown below.
    Title and ProblemCheck: image Your vehicle checks out!
    OdometerCheck: image Your vehicle checks out!
    Vehicle Use and EventCheck: image No vehicle use reported
    Full History: image Detailed information available
    checks_out Your vehicle checks out! AutoCheck's database for this 2004 Ford Mustang Cobra (1FAFP49Y94F163342) shows no negative titles or other problems. When reported to AutoCheck, these events can indicate serious past damage or other significant problems, and disqualifies the vehicle for AutoCheck Buyback Protection. Check the Vehicle Use and EventCheck for reported accidents that can affect vehicle safety and value.
    0 Problem(s) Reported: 15 Title/Problem areas checked:
    image No abandoned title record
    image No damaged title or major damage incident record
    image No fire damaged title record
    image No grey market title record
    image No hail damage title record
    image No insurance loss title or probable total loss record
    image No junk or scrapped title record
    image No manufacturer buyback/lemon title record
    image No odometer problem title record
    image No rebuilt/rebuildable title record
    image No salvage title or salvage auction record
    image No water damaged title record
    image No NHTSA crash test record
    image No frame damage record
    image No recycling facility record
    OdometerCheck
    checks_out Your vehicle checks out! AutoCheck examined the reported odometer readings reported to AutoCheck for this 2004 Ford Mustang Cobra (1FAFP49Y94F163342) and no indication of an odometer rollback or tampering was found. AutoCheck uses business rules to determine if reported odometer readings are significantly less than previously reported values. Not all reported odometer readings are used. Title and auction events also report odometer tampering or breakage.
    0 Problem(s) Reported: Mileage Date Reported
    image 12 04/26/2004
    image 5,000 09/21/2004
    image 6,050 12/20/2004
    image No Additional Information Reported! AutoCheck shows no additional vehicle uses or events reported to AutoCheck for this 2004 Ford Mustang Cobra (1FAFP49Y94F163342). This includes reported vehicle uses such as rental or lease, and events such as whether the vehicle has been reported to have had a loan/lien or duplicate title issued. Other events show if the vehicle has a reported accident and how many calculated accidents or if it has been reported stolen or repossessed. It is recommended to have pre-owned vehicles inspected by a third party prior to purchase.
    0 Event(s) Reported: 6 Vehicle uses checked:
    image No fleet, rental and/or lease use record
    image No taxi use record
    image No police use record
    image No government use record
    image No livery use record
    image No driver education record
    0 Event(s) Reported: 9 Vehicle events checked:
    image No accident record reported through accident data sources
    image No corrected title record
    image No duplicate title record
    image No emission/safety inspection record
    image No loan/lien record
    image No fire damage incident record
    image No repossessed record
    image No theft record
    image No storm area registration/title record
    Full History
    Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text.
    Report Run Date: 2010-02-28 16:17:10.016 EST
    Vehicle: 2004 Ford Mustang Cobra (1FAFP49Y94F163342)
    Event Date Event Location Odometer Reading Data Source Event Detail
    01/07/2004 PA
    Independent Source VEHICLE MANUFACTURED AND SHIPPED TO DEALER
    04/26/2004 PENNINGTON, NJ
    12
    Motor Vehicle Dept. TITLE (Title #:BB200411700000111)
    04/30/2004 PENNINGTON, NJ
    Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
    09/21/2004 NJ
    5,000
    Independent Source INDEPENDENT INSPECTION
    12/20/2004 LAUREL, MD
    6,050
    Motor Vehicle Dept. TITLE (Title #:35074283)
    02/02/2005 LAUREL, MD
    02/13/2007 LAUREL, MD
    02/06/2009 LAUREL, MD
    AutoCheck vehicle history report Terms and Conditions
    This report, and any reliance upon it, is subject to AutoCheck Terms and Conditions. If you obtained the report from a dealer, the dealer has been provided with these Terms & Conditions and can share them with you. These AutoCheck Terms and Conditions are also available at any time at AutoCheck Terms and Conditions or by writing to Experian: Experian Automotive C/O AutoCheck Customer Service 955 American Lane Schaumburg IL 60173
    AutoCheck Buyback Protection Terms and Conditions
    This vehicle (1FAFP49Y94F163342) qualifies for AutoCheck Buyback Protection. If you obtained the report from a dealer, the dealer has been provided with the terms and can share them with you. These Buyback Protection Terms and Conditions are also available to you at any time at Welcome to AutoCheck or by writing to Experian: Experian Automotive C/O AutoCheckCustomer Service 955 American Lane Schaumburg IL 60173
    About AutoCheck
    AutoCheck vehicle history reports by Experian Automotive is the leading vehicle history reporting service. With expert data handling, the Experian Automotive database houses over 4 billion records on a half a billion vehicles. Every AutoCheck vehicle history report will give you confidence when buying or selling your next used vehicle, with superior customer service every step of the way.
    ///M6
    gorgeous!!!! I would deffinitely grab this if I had another $23,000. lol.
    Default cobra
    im very much interested ! how does your car operate in cold wheather like NY ?
    Midtown
    give me a call at 404-234-0535 nmicahel1989. I see no reason for any problems in NY. The car came from Maryland.
    ///M6
    Midtown
    the car hates the pollen as much as I do.
    ///M6
    epic mystic car.....i'm going to try to sell my left nut to duke medical center, and then we'll be in touch
    + = :boobies: / / :idb:
    not
    Small but FIERCE
    IA Member slide_or_die's Avatar
    i seen you on chastain not to long ago with the top down.....its really clean just wish it was lowered a tad bit
    ITS NOT GONNA WORKK!!!! LOL
    Midtown
    It is lowered. It is also GONE!!!
    ///M6
    middle ga
    damn..i saw this on svtp...this may be the only convertable car i would ever drive! wanna trade for a mach 1?
    Midtown
    It's sold.
    ///M6
