Results 1 to 10 of 10
Thread: 1998 Civic help me please
    Oct 2009
    White,Ga
    Unhappy 1998 Civic help me please
    It's a 1998 Honda Civic
    motor-d16y8
    mods-none
    ecu-p2p stock
    Ok my bother was driving his civic came to a stop and it died on him. He had it towed to my house. Lil bro to the rescue. Well I'm puzzled I got spark and fuel. Timing is dead on. It will crank but won't run. I need some help. I'm going to do a compression test and leak down test tomorrow. Does anyone know the psi it suppose to be? Will edit post tomorrow with results. Any help would be greatly appreciated. I put a new distributor on it a month ago with plugs and wires. Also oil reaks of gas!!!! Ok checked ecu its fine. It won't even start and no codes.
    [DIRT] SNOW TARMAC
    Jun 2009
    Braselton
    Check the fuel pump/filter/injectors.
    Oct 2009
    White,Ga
    all good new filter and pump did 4 months ago and still rechecked injectors look good and are spraying good.
    [DIRT] SNOW TARMAC
    Jun 2009
    Braselton
    Hmm idk man. I had a similar issue today, but its the filter.
    ^^this guy loves you jdm-civic's Avatar
    the sky
    try reseting the ecu
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    J.R
    Down South
    standard 184 psi
    Minimum 135 psi
    Their shouldn't be a difference of 28 psi between any cylinder.
    GL!!
    u have no codes at all
    barrow county
    dude you ask some stupid ass question and also give some stupid ass advice
    no offense but im speaking the truth
    does it turn and fire and than die? or just turn but not fire?
    its probably one of the advice they stated above. if it does fire and idle drop than die, probably a vac leak
    the sky
    how is telling somebody something i learned from experience stupid advice? retard.........
    Quote Originally Posted by blue_gt View Post
    i dont know about his dumb questions, but resetting the ECU on a obd2 car is logical. ive seen numerous cars that simply just needed the ECU reset and crunk right up
