Thread: Setup to DEATH
    Default Setup to DEATH
    i just bought a 1998 Acura Integra four door. Find out that the brake line is busted from the front passenger and the rear driver side. People is telling me that i'm going to have to change out the whole brake line system. How much will it cost me? Or how hard will it be to change it out?
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    seems like you would only need to replace what is broken...
    ^^^ u sure? i thought that the back rear brake line is one long line that is connected to the front. im not sure though, didnt look at it. that's just what my brother and his friends told me.
    Senior Member Patterson's Avatar
    Summerville
    if I have rubber lines busting, swelling, ect. I change all of them! no questions
    Summerville
    Quote Originally Posted by hmong_Spec View Post
    Neg. its rubber from caliper to the body then hard line to the master cyl. unless you have a hard line busted then yes you will have to change it or splice it.
    Chattanooga,TN
    Quote Originally Posted by Patterson View Post
    Yup. If its a hard line he can probably just go to a junkyard and get them for cheap.
    ya, its the hard line. What you mean by splice it?
    is it hard to change out the whole hard line?
    Chattanooga,TN
    Just replace the bad section of the line.
    Summerville
    yep get a flare tool and the connectors and just replace the bad section. but oneSLOWex has the best idea. junk yard is the way to go as long as they didn't kill the line with the forklift.
    ok, thanks guys. REPPED.
    Senior Member EJdm's Avatar
    wow that sucks bro...
