Thread: B16A aftermarket parts IM, TB, pistons, rods and more!! built head, crower, venom,
    Oct 2009
    Warner Robins, GA
    Default B16A aftermarket parts IM, TB, pistons, rods and more!! built head, crower, venom,
    I am parting out a B16A JDM motor build I started a long time ago but never finished. All parts are brand new because I never got the motor done before I totaled my del sol out, most I still have the boxes and receipts.I do accept paypal and can ship at your expense. I am willing to meet halfway to atlanta if your buying a good amount of items, in other words, Im not going halfway to atlanta to make $100 sale. If you buy a part from me and its not the right one I do not accept returns so make sure you do your research before you buy. Thanks for looking. call or text 478-952-4027
    Darton solid deck sleeves installed in block and block has been decked part# DS-B1681 $500 (with oil pump, oil pan, pick up tube, cap, girdle)
    Cometic head gasket part# CM-C4168HP (B16A or B18C) $50
    Venom adjustable cam gears part#VENC10-125B(90-99 TEG/99-00 CIV SI) $150 both
    B&M commando fuel pressure regulator $25
    Fuel pressure gauge $20
    Energy suspension motor mount inserts p# 16.1106R $25
    Holly 68mm throttle body 112-540 $180
    Unorthodox under drive pulley set UNR-040600902 $150
    Venom fuel injectors HP621-262 $150
    Air mass comp blue header $160
    Moroso oil pan 20901 w/ pick up tube 24011 $220
    Crower connecting rods (already attached to pistons) B93744B …………………………………… $500 (price is with pistons)
    Arias pistons w/ rings dome shape (were custom made bored .030 over from stock) part# 311855………….
    Venom intake manifold M21-333B $250
    Fuel cooler (6AN fitting) $20
    Installed inside the head and will be sold with head:
    Crower valve springs 68185
    Crower Titanium retainers 87093
    Manley valves custom made (11203-8 PC) valve head DIA: length 4.670 Tip .260, 5 angle valve job, port and polish, flow test, and assy…………………………….$700.
    Attached Thumbnails Attached Thumbnails -cometic-head-gask-jpg   -block-jpg   -block1-jpg   -block3-jpg   -aftermarket-pist-1-jpg
    Oct 2009
    Warner Robins, GA
    more pics
    Attached Thumbnails Attached Thumbnails -air-mass-headers-jpg   -head2-jpg   -oil-pan-jpg   -pully-st-al-11-jpg   -venom-manifold-jpg
    Oct 2009
    Warner Robins, GA
    more
    Attached Thumbnails Attached Thumbnails -venom-cam-gears-jpg   -head-jpg   -head1-jpg   -head2-jpg
    Oct 2009
    Warner Robins, GA
    theMagician JGilbert312's Avatar
    Feb 2010
    Calhoun, GA
    dang i wish I had some cash. GLWS.
    good stuff, glws
    My line of work
    www.internationaljets.com
