Results 1 to 5 of 5
Thread: integra temperature sensor ????
    Certified Gearhead nstygomez's Avatar
    Jul 2009
    marietta
    Default integra temperature sensor ????
    ok so the temp in my cluster does not work anytime that i turn on my car it jumps all the way to hot as if it was overheating. i looked under my hood and i was missing a plus that hooked up to my temp sensor right under my dizzy. i got the plug(obd1) from a friend of mine and rewired it to mine obd2 and still nothing. i know my car is wired wrong because when i turn on my high beams and use a turn signal all the needles on my cluster move up and down until my turn signals or high beams are off or when i hit my emergency lights... idk what it can be im very confused and now that its summer i really wanna fix my temp....anybody had this problem b4???
    to many reasons to list
    aye bro .:Stirfry:.'s Avatar
    yea, i say get a wire diagram and go from there
    ATL DAsquad Member #9
    Augusta
    Check your grounds first. Pull each one off clean it down to bare metal then put them back on. Including the battery terminal.
    Could be a bad temp sensor too.
    Jul 2009
    marietta
    ok ill have to check my grounds then.. and i doubt its the temp sensor i changed it the same day...
    thanks for the help guys
