Results 1 to 3 of 3
Thread: damn i am tired
    ATL, GA
    Default damn i am tired
    so 8 hours and 159 lines of code later my program is 95% done, now i jsut have to figure out how to use jptionpane to output the data instead of the println method
    import java.io.*; //Needed for the file classes
    import java.text.DecimalFormat; //Needed to use DecimalFormat
    import javax.swing.JOptionPane; //Needed for joptionpane
    This program reads data from a file and
    calculates the sales tax on the data
    public class FileSum //class header
    public static void main(String[] args) throws IOException //method header
    String transInfo; //to hold a line read from the file
    double taxRate = .00; //to hold the tax rate based on location
    int number = 0; //to hold an int amount for the variavle transNum
    double amount = .00; //to hold transAmt
    String transDate = "", transNum = "", transAmount = ""; //to hold data from file
    char county = ' '; //to determine the county and thus the sales tax rate percentage
    String location = ""; //to hold the county of the transaction
    int space = 0; //to hold the amount of spaces in the file to seperate the data
    double totalTax = .00; // a counter to hold total sales tax
    double salesTax; //to hold the tax for each transaction
    DecimalFormat formatter = new DecimalFormat("#0.00"); //Needed for decimal format
    // Open the file.
    FileReader freader = new FileReader("test1sampledata.txt");
    BufferedReader inputFile = new BufferedReader(freader);
    // Read the first line from the file
    transInfo = inputFile.readLine();
    //to separate the data read from file to manipulate it
    while (transInfo != null)
    transDate = "";
    transNum = "";
    transAmount = "";
    space = 0;
    for (int i = 0; i < transInfo.length(); i++)
    if (space == 0)
    if (transInfo.charAt(i) != ' ')
    transDate += transInfo.charAt(i);
    else
    space = 1;
    i++;
    if (space == 1)
    transNum += transInfo.charAt(i);
    else
    space = 2;
    i++;
    if (space == 2)
    county = transInfo.charAt(i);
    else
    space = 3;
    i++;
    if (space == 3)
    transAmount += transInfo.charAt(i);
    number = Integer.parseInt(transNum); //converts transNum to int value stored in variable number
    amount = Double.parseDouble(transAmount); //converts transAmount to double value stored in variable amount
    //determine which tax rate to use based on the county
    switch (county)
    case 'A':
    location = "Atlanta";
    taxRate = .08;
    break;
    case 'C':
    location = "Cobb County";
    taxRate = .06;
    break;
    case 'D':
    location = "Dekalb County";
    taxRate = .07;
    break;
    case 'F':
    location = "Fulton County";
    taxRate = .07;
    break;
    case 'G':
    location = "Gwinnett County";
    taxRate = .06;
    break;
    case 'O':
    location = "Out of State";
    taxRate = .00;
    break;
    case 'X':
    location = "Exempt";
    taxRate = .00;
    break;
    default:
    location = "ERROR IN FILE";
    //calculate the tax of each individual transaction
    salesTax = taxRate * amount;
    //calculate the total tax of all transactions added up
    totalTax += taxRate * amount;
    //print the results
    System.out.println("Date: " + transDate);
    System.out.println("Number: " + number);
    System.out.println("Location: " + location);
    System.out.println("Tax: " + formatter.format(taxRate));
    System.out.println("Amount: $" + formatter.format(amount));
    System.out.println("Amount of sales tax owed on this transaction is: &" + formatter.format(salesTax));
    $ I can't believe it's not butter $
    $ Howmuchwoodwouldawoodchuckchuckifawoodchuckcouldch uckwood $
    determining the end of the file by testing the value returned from
    the bufferedreader objects readline method
    System.out.println("The total amount of sales tax owed from all transactions is: $" + formatter.format(totalTax)) ;
    //close the file
    inputFile.close();
    hopefully you all have had a better night/morning than me so far....and i have to work at 9am and class at 5pm...yay......
    TOYOTA TACOMA!!!! 1990wade's Avatar
    BETWEEN MACON AND DUBLIN
    sowwy..................
    I DRIVE A TRUCK THEREFORE MY DICK IS BIGGER THAN YOURS....
    ATL, GA
    Quote Originally Posted by 1990wade View Post
    mmaaaaaaaahhhhhhhhhhhhhhhhhh
