Results 1 to 17 of 17
Thread: 98 Civic LX (alternator)
    Here and there Hulud's Avatar
    Omnipresent
    Default 98 Civic LX (alternator)
    so my gf's car is fucking up. it wont start without a jump and we tested the battery and it fine.
    so i am assuming its the alternator so i want to take it out and have it tested. does anyone know where i can see a diagram to see where it is located before i decide to do this so i know what i need to grab from my parents place which is where my tools are at.
    Val for President
    Mar 2010
    alternator is on its own bracket...i think i got one i can pull though
    Quote Originally Posted by Sir_Christopher View Post
    everyone knows vtec is a mate'n call
    Mar 2010
    heres a halfway decent one but its in the same place i believe on all d series
    http://suspendedhatch.thecarthing.co...z1_diagram.gif
    Omnipresent
    Quote Originally Posted by SlowEG9 View Post
    yea the only honda motor ive ever worked with is an H series on my old prelude
    Val for President
    firewall side on the drivers side.
    Augusta
    Any parts store can test it in the car. Just charge the battery and drive it up there.
    Also could just be the cable, corrosion or bad connection.
    Quote Originally Posted by solblu View Post
    i wouldnt do that. that just asking to get stuck on the side of the road.
    92 Hatch redneckhatch's Avatar
    White Castle
    yea cus that happed to me.
    Omnipresent
    yea dont want that to happen to me
    Val for President
    Projects
    just start the car and pull the positive cable off if it dies then the ALT is fried if it dont it could be just the battery cells are bad.
    Also if you have a volt or ohms meter you can test it compared to stock or required ratings yourself
    Stang Mod slostang's Avatar
    Southside
    diagram for removal / installation...
    http://www.importatlanta.com/forums/...ilton-s-access
    Augusta
    I've driven from Atlanta to Augusta without an alternator belt on before. If you turn off all electronics you will make it 10-15miles to a parts store no problem. When you get there they will charge the battery for free and you can drive back home.
    If you are farther than that from a parts store it would probably be a bad idea.
    im calling bs
    Augusta
    Disconnect your alternator and see how far you get before you call anything.
    Mar 2010
    Macon
    im calling bs
    what car has a dedicated alternator belt that doesnt run anything else like the water pump and vac compressor, because you couldnt go from atl to augusta with no water pump.
    LAWRENCEVILLE
    Check the fuses under the dash first! I had the same issue with my 99 si and it was due to a poped fuse!
    Hella stock member!
    no cupholders ftl Nfire247's Avatar
    Quote Originally Posted by WhoShotJR? View Post
    umm, all d and b series honda motors that i can think use the timing belt to turn the water pump, and have a separate belt for the alternator. just fyi
